ᐅ How can I effectively clean Ikea Pax doors with glass fronts?
Created on: 17 Jun 2019 08:37
adinkla
adinkla
17 Jun 2019 08:37
I am facing the challenge of cleaning the glass panels of my Ikea Pax doors efficiently and gently. I want to take care of both the glass areas and the surrounding frames or other surfaces without causing streaks or damage.
I am especially interested in which cleaning products and techniques you use for the glass, particularly for stubborn dirt like fingerprints, dust, or small water marks. Tips for handling the aluminum elements or the profile frames of the doors are also welcome.
Are there methods to make the cleaning as gentle on the materials as possible while still being effective, perhaps special cloths or sprays? I want to avoid any residue buildup or dulling of the surfaces.
Thank you very much for your advice!
RYANLA42
17 Jun 2019 09:04
Hello adinkla,
I use a simple glass cleaner spray and a microfiber cloth for the glass fronts. This easily removes fingerprints and dust. For the aluminum frames, I use mild dish soap with water and a soft cloth, followed by a quick polish.
Important: Avoid harsh cleaners to prevent scratches or dulling.
miAlessio
18 Jun 2019 14:22
Hello adinkla,
I would like to share a step-by-step guide for cleaning Ikea Pax doors with glass fronts:
- First, remove dust using a dry microfiber cloth to avoid scratches.
- For the glass surfaces, I recommend a pH-neutral glass cleaner or simply a mixture of water and a little vinegar; spray the solution onto the cloth, not directly onto the glass, to prevent drips on the frame.
- Gently scrub the glass surfaces, especially along the edges, to avoid watermarks.
- Use a second dry microfiber cloth to polish afterward, which will give a streak-free shine.
- For the aluminum frames, I suggest lukewarm water with dish soap; also use a soft cloth here and dry afterward.
Avoid abrasive cleaners or harsh chemicals, especially on the frames, as they can quickly become dull. If you want to be on the safe side, test the cleaning solution on an inconspicuous spot first.
Summary: Clean gently, do not spray directly onto the glass, use microfiber cloths—this way the glass and frames stay clean and looking good.
Garthre
19 Jun 2019 19:58
miAlessio schrieb:
Avoid abrasive cleaners or harsh chemicals, especially on the frames, as these can quickly cause dullness.
This is an important note. I would like to add that for Ikea Pax doors with glass fronts, the edges of the glass panels are particularly sensitive. Cleaning with excessive moisture or chemical residues can cause seals to lose adhesion or lead to small deposits forming.
Therefore, I recommend using gentle, specialized glass cleaners for cleaning the glass and thoroughly wringing out the microfiber cloth to avoid excessive moisture.
Additionally, it is important to ensure that no water remains between the frame and the glass, as trapped moisture can develop and potentially cause material damage over time.
In summary: precise and controlled cleaning with minimal moisture, gentle motions, and thorough drying of the edges are essential to maintain the appearance and functionality of the doors in the long term.
