ᐅ How do I easily fix squeaking Billy doors?
Created on: 10 Dec 2023 14:32
leo39
leo39
10 Dec 2023 14:32
Hello everyone, I noticed that the doors on my Ikea Billy bookshelf start squeaking when I open and close them. It’s quite annoying, especially because the noise is quite sharp. I want to fix it as simply as possible and without major disassembly. Are there any proven household remedies or easy tricks to reliably eliminate the squeaking on Billy doors? Ideally, the solution would not require special tools and would be doable for beginners. Thanks in advance for any tips!
noge58
10 Dec 2023 15:18
Hey leo39, it’s great that you want to tackle the problem right away! 🙂 The squeaking on Billy doors usually comes from the hinges or the rollers, which can feel a bit dry over time. My advice: just apply some WD-40 or regular sewing machine oil to the hinges; it works wonders! Very important: don’t use too much, or the doors might get stained. Then open and close the doors a few times so the oil spreads well. Sounds simple, works great, and makes the doors quiet again! 🙂 Good luck, and please let us know how it goes!
GOLO42
10 Dec 2023 17:47
noge58 schrieb:
Just apply some WD-40 or even regular sewing machine oil to the hinges—it works wonders!
That’s a good first step, but I recommend inspecting the hinges carefully before lubricating. Billy shelves usually have simple die-cast hinges that can easily come loose or have their bearings clogged with dust.
Step-by-step guide to optimal repair:
1. Hole and screw check: Make sure the screws are tight and not loose, as the squeaking can also come from a slightly moving hinge.
2. Cleaning: First, thoroughly clean the hinges with a dry cloth to remove dust and dirt.
3. Choice of lubricant: WD-40 can dissolve rust and provide short-term lubrication, but it is not a long-lasting lubricant. Silicone oil or graphite spray are better suited because they do not gum up or dry out quickly.
4. Lubrication: Apply the lubricant sparingly to the moving parts of the hinge. Take care not to spread it over large areas to avoid damaging the wood.
5. Test run: Open and close the door several times to distribute the lubricant and check its function.
One more question: Does the squeaking occur on all doors or only one? It makes sense to locate the exact source, since some models can also have drawer runners causing noise.
Especially with Billy, door alignment can sometimes be an issue—if the doors are not properly aligned, this can also cause noise.
leo39
11 Dec 2023 09:06
GOLO42 schrieb:
One more question: Do all the doors squeak, or just one?
Thanks for the detailed explanation! In my case, only the right door squeaks; the left one is completely silent. I’ve already checked the screws beforehand, and they’re all tight. Dust on the hinges is something I should inspect—that could easily be the cause.
noge58 schrieb:
Just apply some WD-40 or regular sewing machine oil to the hinges
I have WD-40 and sewing machine oil at home, but I’m a bit hesitant about using WD-40 because I read that it’s more of a rust remover than a long-lasting lubricant. Maybe I’ll try the sewing machine oil first.
Are there any specific areas on Billy door hinges that I should be especially careful about? I wouldn’t want anything to go wrong due to improper lubrication—like liquid getting on wood or painted surfaces. And what about possible plastic components in the hinge?
U
usbla
11 Dec 2023 12:54
As a supplement: Billy hinges usually consist of simple pin hinges with plastic bushings. These plastic parts act as bearings and are often the main cause of squeaking noises when they wear out or dry up.
I recommend the following procedure:
1. Cleaning: Remove dirt and dust from the hinge using a brush or a soft cloth.
2. Lubrication: Preferably use a silicone-based lubricant or a special plastic grease. These are less aggressive on plastic than mineral oil-based oils or WD-40.
3. Avoid applying oil directly onto wood or painted surfaces, as oil can leave stains. Apply the lubricant precisely with a cotton swab or small brush.
4. After lubricating, open and close the door several times to distribute the lubricant evenly.
Note: WD-40 is electrically conductive and can soften wood fibers, so its use is only conditionally recommended or not recommended at all for wooden furniture and their fittings.
If the squeaking persists despite lubrication, it is advisable to replace the hinges, since worn plastic bushings are hardly repairable.
noge58
12 Dec 2023 07:21
usbla schrieb:
WD-40 is electrically conductive and can soften wood fibers, which is why it is only partially or not recommended at all for wooden furniture and their fittings.
Good point! 🙂 WD-40 is great for a quick fix, but in the long run, silicone spray is actually better for the Billy hinges.
In my experience, it always helps to apply the lubricant very precisely, as usbla mentioned. And if you’re unsure, start with a small amount and gradually increase it. That’s really important to avoid any stains or damage. Good luck – it’s actually quite easy to do!
