ᐅ How can I discreetly repair small chipped edges on Ikea BESTA units?
Created on: 18 Jan 2020 16:37
Paolo61
Paolo61
18 Jan 2020 16:37
I have some small chips on the edges of my Ikea Besta sideboard. The damaged areas are not very large, but they are visible and disrupt the otherwise simple appearance of the furniture quite a bit. Now I’m wondering what the best and most discreet way to repair these small damages might be.
It is important to me that the result looks good and lasts as long as possible. I’m also interested to know if there are any specific products or techniques suitable for the laminate or melamine surfaces of Besta.
Has anyone had experience repairing these kinds of small chipped edges or can offer advice on the best approach to make the repair spot as unnoticeable as possible?
I look forward to your recommendations!
barsar
18 Jan 2020 17:03
Hello Paolo61,
try treating the chipped area with a suitable repair pen (e.g., furniture or laminate marker). This effectively fills the edge and conceals minor damages quite well. These pens come in various colors, so you can find a matching shade for your BESTA. You might want to apply clear varnish afterwards if the spot is subject to heavy wear.
Julien
19 Jan 2020 09:12
Hello Paolo61,
First of all, it’s great that you want to make the repair as discreet and durable as possible – this will save you a lot of trouble in the long run. For the small chipped edges on Ikea BESTA, it’s worth starting with the right preparation.
- Begin by gently sanding the edge to remove loose particles and ensure good adhesion.
- Then you can fill and color-match the area using furniture repair wax or a repair marker with a matching color.
- If you don’t have repair wax available, wood filler from a hardware store can sometimes work, but you should then touch up the color with markers or felt-tip pens.
Depending on how badly the edges are damaged, a thin film or self-adhesive edge banding could also be an option, though this would be less discreet.
When applying the repair materials, try to make the surface as smooth as possible so the area blends well with the surroundings. If you want, I can give you more detailed tips on sanding or color selection.
Domau0
20 Jan 2020 11:45
Hello Paolo61,
When repairing small chipped edges on Ikea BESTA furniture, I rely on a combination of thorough preparation and precise material selection. Here is a detailed process that I usually follow:
1. Cleaning & Preparation: The damaged area should be free of dust, grease, and solvent residues. A light sanding with very fine sandpaper (grit K800 to K1000) creates a textured surface for better adhesion.
2. Material Selection:
- Repair wax works very well because it is moldable and can be color-matched.
- Plastic filler is suitable for larger missing parts. Make sure the filler is sandable after curing.
3. Color Matching: The most important step is to match the color exactly, as Ikea coatings can be somewhat unique. Some use wood markers, others try acrylic tube paints that also adhere to plastic.
4. Application:
- Apply wax or filler thinly, smoothing out any excess.
- After curing, carefully adjust with very fine sandpaper.
5. Sealing: A thin layer of matte or satin clear coat protects the repair and prevents further chipping.
A quick question: How large are the damaged spots, and are they only on the edges or also on the flat surfaces? The approach varies slightly depending on this.
I hope this helps you so far.
Julien
20 Jan 2020 14:03
Domau0 schrieb:
A quick follow-up: How large are the damaged areas, and are they only on the edges or also on the surface?
This is an important question, especially since surfaces from Ikea are often melamine, which behaves differently than real wood.
If the damage includes the surfaces, the finish is crucial, as basic filler does not always hold permanently on melamine. For edges, however, materials that are easier to repair can be used more effectively.
I also recommend always testing on an inconspicuous spot first to see how the material responds.
Paolo61
21 Jan 2020 08:56
Julien schrieb:
A quick follow-up question: How large are the damaged areas, and are they only on the edges or also on the surface?
Thank you for the follow-up questions; they are very helpful. The chipped areas are indeed only on the outer edges of the fronts and measure up to 1.5 cm (0.6 inches) in length and about 2-3 mm (0.08-0.12 inches) in width. Fortunately, the surfaces themselves are almost undamaged.
This clarifies the situation a bit: these are typically the slight damages that occur on edges of furniture fronts with melamine or laminate coating.
I would prefer to avoid using a large amount of filler, as the surface should remain as smooth as possible and not stand out. A dark color would also not work since the fronts are white.
Are there any special recommendations for white surfaces or paints that have proven effective in achieving an almost invisible repair? Also, how durable are such repairs with frequent opening and closing?
