ᐅ How can I use Ikea PLATSA as a room divider with storage functionality?
Created on: 7 Jun 2022 18:23
Bibar1
I am planning to organize my open living area with a room divider that also provides storage. I am considering the Ikea Platsa system because it is flexible and modular. My main question is: how can I design the Ikea PLATSA as a room divider so that it visually separates the space while maximizing storage without making the room feel crowded?
It is important to me that the room divider does not appear too bulky but is still sturdy enough to hold decorative items and books. Does anyone have experience with arranging and combining the different PLATSA components, and perhaps ideas on how to mix doors, drawers, or open compartments effectively?
I am also interested in tips for securing the room divider if it is freestanding—are there proven methods to ensure stability?
Thanks in advance for your advice!
Jukin
8 Jun 2022 13:47
Hello Bibar1,
I think your question is very well and clearly formulated!
Regarding the connections:
For Platsa as a room divider with the dimensions you mentioned, I recommend at least 5-6 fasteners, especially at the points where the modules meet. This will ensure good stability for the entire construction.
You can generally secure it to the ceiling, but you will need very suitable anchors and fixtures—this can be problematic with suspended or uneven ceilings. It’s worth using flexible brackets that can compensate for small irregularities.
Concerning storage space: I installed a combination of drawers, doors, and open compartments. The soft-close drawers are great. For smaller items, I recommend using boxes or inserts inside the compartments, which can be easily removed.
One more tip: depending on the look you want, you can leave the backs open or add lightweight backing panels – this greatly affects the sense of space.
If your PLATSA room divider needs a finishing side panel, you can cover it with matching side panels or standard decorative panels.
If you like, I can also help you with the planning, especially regarding the modular layout.
kemeo68
8 Jun 2022 15:58
Bibar1 schrieb:
What do you think about combining tall cabinets with individual integrated drawers?
To be honest, I often find this classic layout quite boring and lacking innovation.
Why not be bolder with open shelving? Instead of hiding everything behind doors, a mix of visible and concealed storage can give the room divider character.
And regarding stability: If you really think PLATSA is strong enough for freestanding constructions without solid reinforcements or steel frameworks, then you are underestimating safety and long-term quality. I have personally seen the system give way under full load when it is not properly secured.
My advice: Be courageous with experimentation, but don’t cut corners when it comes to fastenings. Otherwise, you’ll soon end up with an unstable pile of boards instead of an aesthetically pleasing room divider.
