ᐅ How should I handle damaged Malm furniture finishes?
Created on: 25 Dec 2015 14:07
Ploan
Hello everyone, I am currently facing an issue where the coatings on several of my IKEA Malm furniture pieces are cracking or peeling off in multiple places. Since these are supposed to be melamine surfaces, I had expected the coating to be much more durable. However, as I am not sure whether this is due to manufacturing defects, material fatigue, or possibly incorrect handling on my part, I would like to ask: How do you deal with damaged Malm furniture coatings? Has anyone had experience with repairs, replacements, or even professional refinishing? I would appreciate concrete tips or recommendations for suitable products for care or touch-ups.
Clementbla
26 Dec 2015 12:40
dinano schrieb:
some melamine surfaces show initial damage after just one to two years
I had no issues with my Malm furniture after 3 years. It would be interesting to know whether improper loading or direct moisture caused the damage.
V
valerie-tr
27 Dec 2015 08:17
I would like to add one more point that is often overlooked: The edges of Malm furniture are particularly vulnerable because the melamine resin is often applied very thinly or not continuously there. As a result, coatings often peel off at the edges even with minor impact or stress.
In such cases, I recommend sealing the edges additionally with clear varnish or special protective films to prevent further peeling. Although this involves a small extra effort, it can significantly extend the lifespan of older furniture.
It is also important that repair work uses compatible materials, as otherwise tensions can develop between layers, which in turn promote peeling.
Finally, a question: How do you store repair materials? Do you keep the furniture in a heated or rather cool room? This actually affects the behavior of the coating and the adhesive.
Ploan
27 Dec 2015 09:55
That exactly matches my observation. Most of the damage is on the edges or on the front edges of the drawers.
I keep the furniture in a heated room, but there was once a small water damage near one spot, which might also be part of the cause.
Thanks for the tip about clear lacquer or protective film; I will consider that.
One last question to everyone: Are there any recommendations for clear lacquers or protective films that are truly compatible with melamine coatings and have proven effective?
