ᐅ How do I customize IKEA Metod cabinets to fit non-standard dimensions?
Created on: 22 Jun 2015 17:23
nudoja
I am planning to install IKEA Metod cabinets in my kitchen, but I am facing the problem that the dimensions of my niche or the space do not match the standard sizes. Therefore, I am wondering: How can I customize IKEA Metod cabinets to fit non-standard dimensions without losing too much convenience or stability?
Specifically, I am dealing with narrow and slightly irregular gaps that cannot be filled with standard furniture. So far, I have considered whether shortening the side panels is possible, whether special filler pieces make sense, or if using concealed connectors might help.
Are there any proven tips or experiences on how to modify dimensions, adapt components, or create precise-fit solutions with Metod? Where are the limits when it comes to modifications?
Thanks for your input!
nudoja
23 Jun 2015 15:37
Thank you for the previous suggestions; they have already been very helpful!
To add some details: This concerns a kitchen with two main issues. First, there is a recess about 2 cm (1 inch) narrower than the double standard cabinet carcass, so approximately 118 cm (46.5 inches) instead of 120 cm (47 inches). I could probably consider trimming the side panels there.
Second, there is a space between the wall and door frame measuring about 7 cm (3 inches) wide, 60 cm (24 inches) high, and 40 cm (16 inches) deep, which is intended for a tall cabinet, but no standard Metod cabinet fits. I initially thought about a horizontal filler panel, but I simply do not have more than 7 cm (3 inches) of space.
What would you recommend in this case? Is it possible to convert a side panel into a narrow shelf or a filler with an opening function? And what fittings would be suitable here?
Enrico4
24 Jun 2015 08:15
For the 7cm (3 inches) gap, a completely custom solution is probably more practical than trying to modify a standard Metod cabinet frame.
- A narrow filler panel made from matching material should be fitted with hinges specifically designed for small doors, such as low-profile soft-close hinges.
- Alternatively, folding or sliding mechanisms can be considered, though they are more complex to implement.
- Ensure all modifications are securely fastened to adjacent cabinets or the wall.
- For the area with a width of 118cm (46 inches), it is usually sufficient to shorten each cabinet frame by 1cm (0.4 inches) so that standard 60cm (24 inches) wide Metod units can be placed side by side.
Pay special attention to carefully finishing the cut edges, especially in tight spaces, to prevent moisture ingress.
TELAHAU
24 Jun 2015 10:42
nudoja schrieb:
What would you recommend in this case? Is it possible to build a narrow shelf or a panel with an opening function out of a side wall, for example?
Yes, you can. Build this kind of panel as a narrow cabinet with hinges and a door handle (it can also be magnetic). Small items can fit inside. Important: measure very precisely and use good quality hinges.
