ᐅ How can I customize IKEA Besta drawers with self-made inserts?
Created on: 17 Oct 2024 19:23
Luson48Hello everyone,
I am currently planning to assemble my IKEA Besta drawers and want to customize them with homemade inserts. The goal is to tailor the interior layout precisely to my needs, for example, to organize cutlery, stationery, or small items efficiently.
I am especially interested in how you best adapt the inserts to the Besta drawers, which materials are suitable, and how to fix the inserts so they remain stable but still can be moved flexibly.
It would also be helpful to have tips on accurately measuring the inside dimensions of the drawers or tricks to account for cutouts for cables or other special features in the cabinet.
Who has experience with customizing Besta drawer interiors and can explain step by step how to approach this best?
Thanks in advance!
Thanks in advance!
Hello Luson48,
I think your project is great because custom inserts can really optimize storage space. Here is a structured approach on how I would tackle it:
- First, measure the internal dimensions of the drawer very precisely: width, depth, and height, preferably using a caliper or a good metal measuring tape (wood can expand and distort the measurement).
- For the inserts, wood or MDF panels with a thickness of 6–10 mm (0.24–0.4 inches) work well because they are sturdy and easy to work with. Plastic is also possible if you have the appropriate tools.
- Important: You should consider whether the inserts will be glued, slotted, or screwed in place. For example, you can attach strips to the drawer bottom where the inserts can simply be slid in—this keeps everything flexible.
- To prevent the inserts from wobbling, use small magnets or rubber buffers at the edges. This ensures a secure fit without causing damage.
- Cable passages or cutouts can be precisely made with a jigsaw or a router. Important: sand the edges well to prevent catching.
- One more tip: before cutting, make a sketch with all measurements and planned compartments. This helps avoid mistakes and saves time.
If you like, I can show you an example of how I designed my cutlery inserts.
Hope this helps you get started!
Jensson schrieb:
Wood or MDF panels with a thickness of 6–10 mm (1/4–3/8 inch) work well for inserts because they are sturdy and easy to work with.I agree with this but would like to add that you should choose the material based on how it will be used. For example, for heavier items or high stress, I recommend strong plywood panels or hardwood strips since they offer somewhat better tensile and compressive strength than MDF.
Also, when building the inserts, always remember to round off or deburr the edges after cutting – especially with MDF, as the dust can be unpleasant and harmful.
Regarding the height of the inserts: Besta drawers typically have an internal depth of about 36 cm (14 inches) and a maximum installation depth within the carcass of around 38 cm (15 inches). You need to take this into account when planning, especially if you have cutouts for cables or other fittings.
Jensson schrieb:
Wood or MDF panels with a thickness of 6–10 mm (1/4–3/8 inch) work well for insertsDepending on whether your inserts are guided along the drawer sides or laid loosely, you will need different construction methods. For guided inserts, I suggest attaching narrow strips to the inside of the drawer along which the inserts can slide. Counterprofiles then prevent slipping.
Can you say how much weight the drawers will need to support, and whether you prefer a rigid, fixed partition or a more flexible, interchangeable layout? This helps a lot, as the fixing method varies considerably depending on that.
One more technical note: For cutouts for cables, I recommend precise measurement with a pointed measurement probe to make sure there is enough space – unlike theoretical dimensions, it’s best to measure realistically, often directly on the furniture.
I would even recommend starting with prototypes made from inexpensive scrap boards to test the system before the final cuts.
