ᐅ How can I customize IKEA Besta doors with paint or decorative finishes?
Created on: 31 Aug 2023 09:37
sonso3
sonso3
31 Aug 2023 09:37
I’m currently considering how to customize my IKEA Besta doors without completely replacing them. I’m especially interested in methods that involve using either paint or various decorative finishes.
I would like to know which types of paint work best on the surface of Besta doors (e.g., acrylic, lacquer, or spray paint?), what kind of preparation is needed (e.g., sanding, priming), and how well such treatments adhere and how durable they are.
Also, does anyone have experience with applying films or special decorative panels to the doors? How easy or demanding is the application process, and what does the result look like after a few months?
I’m looking forward to your tips and would appreciate examples of how you have creatively customized your Besta doors.
Thanks in advance!
fredle
31 Aug 2023 10:42
Hello sonso3,
I understand your question well and have personally customized several IKEA Besta doors with paint and decorative finishes. Here is a simple step-by-step guide for working with paint, along with some tips on alternatives like adhesive films:
1. Preparation:
- Remove the doors from the cabinet.
- Clean thoroughly to remove grease and dust.
- Lightly sand the surface (grit 240 to 320) – this improves paint adhesion.
- For larger dents or scratches, you can use a light filler.
2. Primer:
- For smooth surfaces, I highly recommend using a primer to ensure better paint adhesion. A matte sealer or bonding primer works best.
3. Paint choice:
- Water-based acrylic or acrylic lacquer is suitable for furniture and has a mild odor.
- Spray paint can be faster, but requires a very clean and well-ventilated area.
- Choose high-quality paint designed for furniture and heavy wear.
4. Painting:
- Apply at least two thin coats. Lightly sand between coats (fine grit 400+).
5. Sealing:
- Optionally, you can apply a clear coat (matte or glossy) after painting to increase protection.
On films and decorative panels:
- Self-adhesive films are an easy and reversible option, but the surface must be very smooth.
- You can remove air bubbles well using a squeegee or plastic spatula.
- High-quality decorative panels made from thin MDF are more durable, but require more effort to cut and install.
Regarding durability, well-painted doors last several years. With films, you need to watch out for scratches and wear.
If you like, I can also share tips on how to mask off designs neatly using stencils or painter’s tape.
fredle
FAVALERIE9
31 Aug 2023 11:23
I would recommend using matte acrylic lacquer. It is easy to apply and has a high-quality appearance.
For films, please ensure the surface is smooth and work slowly to avoid bubbles forming.
loken
1 Sep 2023 14:05
fredle schrieb:
Make sure to use high-quality paint designed for furniture and heavy wear.
Great tip, thanks!
Last year, I transformed my Besta doors using a combination of paint and veneer – it went really quickly and looks fantastic. When painting, I treated myself to both a roller and a brush to get a nice even finish on the surface.
And if the DIY doesn’t go as planned: you can simply buy new doors – but for me, adding a personal touch brings a lot more enjoyment. It helps me to just enjoy the process, even if everything doesn’t turn out perfect.
A little secret tip: before painting, gently polish the doors with fine steel wool after sanding. It makes the surface super smooth and even.
Good luck and remember: every flaw has its own charm 😉
SANMAR
2 Sep 2023 08:17
Hello sonso3, I can well understand that you might feel uncertain at times with a project like this – especially with all the steps and materials involved. I felt the same way when I refurbished my Besta doors.
I think it’s important to clearly define your preferences: Do you want a matte finish, or is a glossy one also acceptable? What kind of look are you aiming for? For me, it was a natural wood appearance, which I achieved using the right stain and clear varnish.
I also understand that the effort can sometimes feel overwhelming. It’s important to take enough time for each step and to take breaks in between to avoid stress.
If you like, I can also share tips on how to organize your work effectively and which materials I personally ordered or tested.
I wish you lots of success, and if you ever feel stuck, just ask again here in the forum – we’re happy to help!
fredle
2 Sep 2023 10:54
sonso3 schrieb:
Does anyone have experience with films or special decorative panels and their application on doors?
Yes, here are a few additional tips:
You should always apply films to a pre-treated, smooth, and clean surface – ideally, lightly sand and dust it beforehand. For the best result, a squeegee is essential to avoid bubbles.
For decorative panels made of MDF or similar materials, you will also need appropriate edge profiles to ensure durability and a high-quality appearance. These can be attached with special mounting adhesives, and you should cut them to cover the entire door surface.
Finally, if you plan to clean the door frequently, water-based paints are more practical. Films also hold up well, but if you use highly abrasive cleaning agents, they wear out faster.
If you need more details, I’m happy to help.
