ᐅ How do I properly document defective Malm furniture to make a warranty claim?
Created on: 12 Jan 2020 08:43
Gukla45
Hello everyone, some time ago I bought Malm furniture from Ikea and have now unfortunately discovered some defects. To make a warranty claim, I want to report the damage correctly and clearly. My question is: What is the best and proper way to present defective Malm furniture for a warranty claim? What specific steps should I take, which information is important, and how can I document the defects properly so that Ikea can respond without any issues? I know photos are important, but are there any special things to consider here? Thanks in advance for your helpful tips and experiences!
Sinan-meo12 Jan 2020 12:14Gukla45 schrieb:
Do you think it makes sense to explicitly refer to the instruction manual and load limits in the letter to Ikea, in order to exclude the defect being caused by me as the customer?Yes, that is a very good idea. It shows that you have familiarized yourself with the product and have not made any obvious mistakes in its use. This strengthens your justified claim and allows you to better counter any arguments Ikea might present.
GUSTAVO5612 Jan 2020 12:50I would like to add the following: If the defect, for example, breaks through the bottom of a drawer, you should also check whether the mounting screws on the sides are properly secured. Such damage often occurs due to uneven load or assembly defects.
From my experience, document not only the obvious damage but also the quality of the assembly. If possible, keep the original packaging or installation instructions as proof.
Regarding the next steps: Write your report objectively, referring to the legal warranty (usually 2 years in Germany) as well as Ikea’s warranty conditions.
Important: Ask how the replacement or repair will be carried out and which steps Ikea recommends to ensure a quick resolution.
I believe there is an important fundamental question here: Is the piece of furniture truly defective due to a manufacturing fault, or was there perhaps user error that is not immediately obvious?
That is a valid argument; however, you should also be prepared for Ikea to question whether the load limits were respected or even to request evidence of proper use. Therefore, avoid assumptions or assigning blame in your letter and try to remain as objective as possible.
Gukla45 schrieb:
Do you think it makes sense to explicitly refer to the user manual and load limits in the letter to Ikea?
PECLARISSA12 Jan 2020 14:02What I always find helpful: When you make a complaint, being polite and clear often has a better effect. 🙂
I always keep my purchase receipt as a PDF on my phone for quick access when contacting Ikea. I also briefly explain in my message what is broken, when I noticed it, and politely ask about the next steps. My tip: Don’t write too complicated, just be clear and courteous 🙂
Sinan-meo schrieb:
Also note when you purchased the furniture and keep the purchase receipt ready.
Most important in terms of procedure:
1. Take photos (in good lighting), clearly document all damaged areas
2. Keep the purchase receipt ready
3. Describe the defect briefly and precisely, for example, "Drawer bottom broken despite adhering to the load limits"
4. Send an email to Ikea or use their complaint form
You don’t need anything else; they usually handle the rest.
A small addition from me: Even better than just taking photos is often marking the damage area before packing, so Ikea technicians know exactly where the problem is when they do the repair.
I always use small colorful sticky flags to mark damaged spots. This saves time and avoids confusion. 🙂
Also: When sending in or picking up, insist on a receipt and have all the information about the claim documented.
