ᐅ How can I modify IKEA BESTA units to create a room divider with open sections?
Created on: 8 May 2020 08:34
sodoso
Hello everyone, I am considering how to redesign my IKEA Besta system to function effectively as a room divider. Specifically, I want to incorporate as many open elements as possible to create an airy separation between two living areas without making the space feel completely closed off. I already have some plans, but I’m still looking for a solid approach to integrate the open elements without compromising stability and functionality. Does anyone have experience or tips on converting BESTA units into a room divider with open compartments? I’m especially interested in suggestions for connecting the units, possible modifications to the back panels, and the best combination of doors, drawers, and open cases.
RON57 schrieb:
Additionally, decorative elements can be placed inside to add structure to the appearance. This is an important point because purely open compartments can quickly look chaotic. A combination of open and closed compartments creates a sense of calm and maintains clarity. Back panels made of glass or acrylic can also serve as transparent alternatives while simultaneously increasing stability.
sodoso schrieb:
The connection needs to be stable so that the room divider doesn’t wobble or tip over when touched. I’m specifically interested in whether you plan to use the room divider just as a simple partition wall or also as a dividing wall with seating or workspace function. The load requirements greatly influence the connection method. Also, whether the room divider should extend all the way to the ceiling or only be half-height.
In response to your question: The room divider should be about 180 cm (70.9 inches) high, so it stays just below the ceiling, and it does not have a load-bearing function. It is located in an open living-dining area and mainly serves as a visual boundary and storage space. It will only be subjected to occasional leaning – it is not designed for sitting on top. It is important to me that it remains stable and appears visually lightweight.
Matthewt488 May 2020 15:23The 180cm (70.9 inches) size is ideal for Besta, as it stacks well and still looks transparent. Important: connect the modules on the side using the original IKEA connector fittings. Remove the back panels to create openness, and use sturdy shelves in the open compartments. For additional stability on the wall side, you can secure it to the wall with small brackets – this improves safety and prevents tipping. This way, it remains flexible and secure.
I find your idea really interesting! I noticed with my room divider that loose items tend to accumulate quickly in the open compartments, attracting dust. A combination of open sections and closed compartments has proven to be a good solution for me, not only visually but also practically. You can tell that while the open design brings a sense of airiness, it also requires maintenance and tidiness.
