ᐅ How do I connect open and closed compartments in an Ikea BESTA shelving unit?
Created on: 30 Apr 2020 18:12
Maedouard
Hello everyone, I am planning to build an Ikea BESTÅ shelving unit, where I want to combine both open and closed compartments. I am wondering what the best way is to integrate these open and closed modules into a cohesive shelving unit, especially how to create a harmonious appearance and achieve the most stable assembly. Are there any proven methods or specific connectors that work well for this? I am particularly interested in whether there are special considerations when mixing typical BESTÅ elements with and without doors in a single shelving wall, both in terms of aesthetics and stability or alignment. I look forward to any tips and experience you can share!
Maedouard3 May 2020 07:59Alberto51 schrieb:
Some time ago, I combined my BESTÅ system using both open and closed compartments, and the biggest challenge for me was keeping the appearance consistent.Thank you very much for this tip; it really resonates with me since my main goal is the look. Are there any special tricks to better align the gaps or fronts? I noticed on the Ikea website that the compartments often have small gaps – what is the best way to hide or avoid these?
flota schrieb:
I would like to agree with that. Additionally, I would recommend checking before assembly that all modules are standing on a level surface, as small unevenness can negatively affect doors and alignment later on.That’s a great tip, especially since I’ll be dealing with older floors; do you have any recommendations on how to best compensate for that?
Maedouard schrieb:
Are there any special tips on how to better align the gaps or fronts?Yes, there are definitely some options:
- Use the adjustment screws on the hinges to align the doors precisely with minimal effort.
- You can conceal small gaps with wooden dowels or small plastic cover strips.
- To avoid gaps, thin paintable trim or cover strips can be used, especially for open compartments.
- To compensate for uneven floors, adjustable feet (like those from IKEA) can be installed under the unit. Additionally, small wedges made of wood or plastic can be helpful.
Maedouard schrieb:
I saw on the IKEA website that the compartments often have small gaps – how can I best conceal or avoid them?These gaps often occur due to irregularities in the furniture itself or the floor. The best way to avoid them is careful alignment and, if necessary, touch-ups with small cover strips.
If you like, I can recommend some video tutorials that explain this very clearly.
