ᐅ How do I connect a 1-inch internal thread to a 20x2 mm PE hose/pipe?
Created on: 22 Jun 2023 14:59
frankmehlhop
frankmehlhop
22 Jun 2023 14:59
For a water connection, I want to create a connection between a 1-inch internal thread metal fitting and a PE hose/pipe 20x2mm (max 16 bar, DVGW approved for drinking water).
How and with what can I connect these two elements?
Bardamu
22 Jun 2023 20:03
Hi,
I haven’t done this yet, but there is a brass fitting designed for something like this. On one side, it has a male thread, and on the other side, it has a connection with a female thread.
Nida35a22 Jun 2023 20:35
frankmehlhop schrieb:
Connection from 1 inch internal thread metal to a [B]PE hose/pipe 20x2mm (max 16 bar,
check the datasheet of the metal part,
internal thread BSP tapered,
or internal thread BSP parallel,
or NPT tapered or parallel?
frankmehlhop
23 Jun 2023 14:13
I do not have a datasheet for it.
Nida35a23 Jun 2023 16:49
I don’t have a datasheet for that
Then bring the metal part as a sample, and the seller will find the right part for you
rick201825 Jun 2023 20:54
Use the appropriate fittings, for example from Unidelta.
