ᐅ How can I combine open and closed compartments with Ikea BESTA?
Created on: 12 May 2023 18:42
Reoxenia36R
Reoxenia3612 May 2023 18:42Hello everyone, I plan to set up my Ikea Besta system using a combination of open and closed compartments to accommodate both storage and decorative items. My question is: How can I combine open and closed compartments in Ikea Besta so that the overall look is harmonious while maintaining functionality? I’m wondering if there are any fixed rules or proven design principles to consider when arranging them, how many open units work well, and if there are tips for balancing color, size, or positioning. Maybe someone has practical experience or design recommendations that go beyond the usual IKEA kits. Looking forward to your suggestions!
Reoxenia36 schrieb:
How can I combine open and closed compartments in Ikea BESTA units so that the overall look is harmonious while maintaining functionality?Great question! I believe the key is to create a good rhythm – like a dance between openness and concealment. 💃
My advice: start with a basic structure, for example, several closed compartments as a foundation to hide storage, and then add individual open compartments strategically as "breathing spaces" to keep the overall design light and lively. You can enhance this effect with matching decorative elements to create attractive focal points.
And don’t be afraid to experiment – who says everything has to be symmetrical? Asymmetrical combinations can make the look modern and interesting! 😊
Reoxenia36 schrieb:
How can I combine open and closed compartments in Ikea BESTA units so that the overall appearance is harmonious while maintaining functionality?I would recommend mixing open and closed compartments evenly. For example, a 50/50 split or 60/40 favoring the closed compartments to avoid visual clutter. Use open compartments for decorations and closed ones for storage. Important: choose compartments with the same height and width.
The combination of open and closed compartments in Ikea BESTA mainly depends on the room layout, intended use, and personal style. Detailed planning is crucial: What are the dimensions of each unit? Are you using heights of 40 cm (16 inches) or 64 cm (25 inches)?
- Positioning: Open compartments should not be placed directly on the floor to maintain a clear sightline and reduce dust accumulation.
- Weight: Closed compartments are better suited for heavier items, as they often appear more stable and provide a greater sense of order.
- Material mix: Whether doors are made of glass, wood, or the same color as the frame, this significantly affects the overall look.
It is recommended to create a sketch or use a digital planning tool (such as the Ikea planner) beforehand to experiment with different setups. Additionally, lighting open compartments with LED strips can greatly enhance the overall impression.
May I ask how large your room is and how many BESTA units you plan to use? Then I can provide more specific advice.
JORGERON schrieb:
I would recommend mixing open and closed compartments evenly. Exactly! I also filled the open shelves with plants and a few nice pictures – it really brings life into the space! 😄
Katan schrieb:
You can enhance the color scheme with matching decorative elements – it creates great eye-catchers. Great tip! I can only say: Don’t be afraid to creatively style the open shelves. And if you’re unsure, start by leaving just a few open. This way, no room feels cluttered – but you still keep that lively touch.
It’s not only practical but also a lot of fun to customize the system to your own style!
Reoxenia36 schrieb:
How can I combine open and closed compartments in Ikea BESTA units so that the overall look is harmonious while maintaining functionality?I often wonder if this constant fear of clutter with open compartments is simply exaggerated. Most people tend to overload the open compartments due to poor selection, not because of the concept itself.
Personally, I find a clear structure more important than the ratio of open to closed sections. I prefer a few, well-thought-out open areas rather than many half-filled ones.
Also, closed compartments are often just plain boring and encourage hiding things rather than choosing what to display. Why not have everything open but well organized? I don’t want to see chaos in cabinet form.
Who says tidiness can only happen behind doors? A more interesting discussion would focus on everyday practicality, rather than visual restrictions.
