ᐅ How do I properly attach IKEA Metod toe kicks to built-in kitchens?
Created on: 15 Mar 2017 21:11
Lakau
Lakau
15 Mar 2017 21:11
I am currently facing the challenge of installing the baseboards for the IKEA Metod fitted kitchen neatly and correctly. I want to avoid unsightly gaps between the floor and the baseboards or the baseboards not holding securely. My question is: What is the best way to install the IKEA Metod baseboards on fitted kitchens so that they finish cleanly and are securely fixed for the long term? Are there any special tips or tools I should pay attention to?
The situation is as follows: The kitchen floor is not perfectly level, and the gap between the lower cabinet carcass and the floor varies slightly. Also, it will probably be a bit tricky around the corners.
I look forward to your experiences and tips that can help me here!
Shawn38
15 Mar 2017 21:42
Hello Lakau,
regarding your question about how to properly attach IKEA Metod baseboards to fitted kitchens, I can offer you some useful tips.
First: The kitchen floor should be as level as possible before installation. If it isn’t, you can use small leveling or spacing wedges under the base cabinets to ensure a consistent height.
Then proceed as follows:
- First, mount the baseboard brackets (either on the back of the baseboard or on the cabinet carcass, depending on the model) with the supplied clips or screws.
- Position the baseboards so they rest flush on the floor as much as possible. If the floor is uneven, leave some space at the back to prevent the baseboard from being forced upwards.
- For corners, it is often recommended to use special corner connectors so the baseboards join neatly and create a precise contour.
- It is important to place the baseboard brackets so that the baseboard sits firmly and without wobbling.
A tip for the finishing touch: Use a thin bead of sealant or silicone in the color of the floor to make any small gaps between the floor and baseboard invisible.
If you want, I can also explain in more detail how to best implement the corner solutions.
karpu3
16 Mar 2017 07:33
I would simply use the supplied holders and press the baseboards lightly, not too hard. If the floor is uneven, use shims or seal with silicone. Install corner connectors for a neat finish.
klabe
16 Mar 2017 14:29
Hello Lakau,
I fully agree with Shawn38 and would like to offer you a simple step-by-step guide to help you install the baseboards of your IKEA Metod kitchen cleanly and professionally.
1. Preparation:
- Check your kitchen floor with a spirit level and correct any unevenness using suitable wedges or shims.
- Thoroughly clean the underside of the base cabinets and the floor.
2. Mounting the baseboard brackets:
- Attach the supplied brackets at regular intervals under the base cabinets, for example every 40-50cm (16-20 inches).
- Pay special attention to the corners, as these are often not perfectly square. It helps to mount the brackets slightly angled or offset here.
3. Installing the baseboards:
- Press the baseboards into the brackets until they fit snugly and without any play.
- For joints or corners, use the appropriate corner connectors or cut the boards to fit with a miter saw.
4. Fine adjustment:
- For small gaps between the floor and the baseboard, you can use color-matched acrylic or silicone. This also protects against moisture.
5. Check:
- Make sure the baseboards are securely seated and no light shines through.
Common mistakes include the baseboards snapping in too loosely, missing corner connectors, or neglecting floor unevenness.
I hope this helps you!
suru61
17 Mar 2017 09:56
Shawn38 schrieb:
If the floor is uneven, leave some space at the back so the baseboard doesn’t get pushed out.
Glad to hear it’s working out the same way for you! I believe the most important thing is to install the baseboards without forcing them, otherwise they often develop cracks or unsightly distortions. A little gap and a clean cut really make a big difference.
One more tip from me: If you’re a bit handy, it’s worth lightly adjusting the corners of the baseboards yourself using a fine file or sanding block. This makes fitting them much easier – giving your installation a personal touch!
All in all: stay relaxed and don’t be too rigid, and you’ll achieve a neat baseboard finish.
