ᐅ What is the quickest way to clean the interior surfaces of IKEA Metod cabinets?
Created on: 2 Jul 2021 09:37
fe_siamand
fe_siamand
2 Jul 2021 09:37
Hello everyone, I recently bought a kitchen with IKEA Metod cabinets and am wondering about the quickest yet gentle way to clean the interior surfaces of these cabinets. The surfaces seem to be lacquered or melamine-coated, and I want to avoid scratches or damage. Are there any special cleaning products or home remedies that work particularly well? Additionally, I’m interested in whether heavy grease or dirt can be removed quickly and effectively without damaging the inside. I would appreciate tips that ideally require little effort, as I am short on time.
Henry
2 Jul 2021 10:15
Hello, I completely understand your concern! Especially with new cabinets, you want to avoid mistakes and keep them looking good for as long as possible. I had a similar experience when I cleaned my IKEA Metod cabinets. What helped me was using a soft microfiber cloth and pH-neutral all-purpose cleaners. This prevented scratches and made it easier to remove grease. I understand you’re under time pressure, but even a short application of the cleaner often helped to loosen stubborn dirt. It’s important not to make the surfaces too wet, as the material can sometimes swell. If it helps, I can provide more details about the specific cleaners I used.
Gregory
2 Jul 2021 11:03
For quick and gentle cleaning of IKEA Metod cabinet interiors, I recommend the following procedure: - Use only mild, non-abrasive cleaning agents. pH-neutral all-purpose cleaners or mild dish soap diluted in water work best. - Lightly dampen a soft microfiber cloth and wipe the surfaces to remove dirt and grease. - For tougher stains, allow the cleaner to sit briefly before wiping it off. - Avoid using harsh solvents, abrasive cleaners, or scrubbing pads, as these can damage the surface. - Use a lint-free cloth for drying to prevent water spots. This method saves time and preserves the material quality.
REPITAR
2 Jul 2021 11:45
A brief tutorial for quick and safe cleaning of the IKEA Metod cabinet interiors: 1. Preparation: Get a clean, soft microfiber cloth and a spray bottle with a mild cleaning agent (pH-neutral, e.g., delicate detergent or gentle all-purpose cleaner). 2. Cleaning: Spray the cleaner directly onto the cloth, not onto the surface. Wipe the surfaces carefully to remove dirt and grease. 3. Stubborn stains: For persistent residues, let the cleaner sit for a short time (1-2 minutes). If needed, wipe gently again. 4. Finishing: Dry the surfaces with a second clean microfiber cloth to prevent water spots or moisture damage. Mistakes to avoid: never use aggressive abrasive cleaners or use too much water, as this can cause the surface to swell. This method offers a good balance between speed and material protection.
PRABAU
2 Jul 2021 12:12
A microfiber cloth and dish soap water are usually sufficient. Wipe quickly; do not soak. For grease, let it sit for a short time, then wipe again. Do not use abrasive sponges or harsh chemicals.
Henry
2 Jul 2021 14:23
PRABAU schrieb:
Microfiber cloth and dish soap water are usually sufficient.
I agree with that, but I still found it helpful to wring out the cloth occasionally to prevent dirt from setting in.
Also, I would recommend cleaning the cabinets in the evening, as the humidity in the air helps protect the surfaces. I once had an issue where the edges slightly swollen due to too much moisture.
How do others feel about this, especially regarding the time it takes?
