ᐅ How can I clean matte Ikea Metod cabinet fronts without leaving streaks?
Created on: 21 May 2023 16:37
Gije52
Gije52
21 May 2023 16:37
Hello everyone, I have matte Ikea Metod fronts in my kitchen and I often encounter the problem that, despite careful cleaning, unpleasant streaks appear. I would be interested to know which cleaning methods or products you would recommend to clean the matte surface effectively and gently, without leaving streaks. It is also important for me to know if certain cloths or cleaning techniques work better than others. So far, I have used a mild all-purpose cleaner and a microfiber cloth, but especially in daylight, streaks and spots are often visible, which really affects the appearance. Does anyone have experience or tips on how to clean this matte surface without streaks?
SUBEN60
21 May 2023 18:12
Cleaning matte Ikea Metod fronts without leaving streaks is definitely achievable if you keep a few points in mind. First: only use soft microfiber cloths, as these protect the delicate matte surface and prevent lint. For cleaning agents, I recommend diluted, neutral dishwashing detergent solutions. Strongly alkaline or solvent-based cleaners can damage the matte texture and cause streaks or shiny spots.
Clean the fronts in circular motions and follow up by wiping with clear water to remove all detergent residues. It is important to wring out the cloth afterward so that no drops or overly wet cloth wet the surface, as this often causes streaking. Then, the surfaces should be wiped again with a dry, lint-free cloth to completely remove any remaining moisture.
In summary: - Use a soft microfiber cloth - Use a mild dishwashing detergent solution - Carefully wipe with clear water afterward - Polish dry with a dry cloth
This is how I have been able to clean many matte surfaces streak-free.
angel
22 May 2023 08:59
I can fully support the previous comments and would like to add a few points:
Matte surfaces are particularly prone to showing visible streaks if cleaning agent residues or water spots are not completely removed. Additionally, the way you use the cloth is crucial. A tip I always give is to rinse the microfiber cloth well before cleaning and use it slightly damp, as overly wet cloths can also cause streaks.
You should also avoid aggressive cleaners, meaning no abrasive scrubbing agents or alcohol-based products, as these often damage the matte finish.
It is very helpful to polish the surface with a dry cotton or microfiber cloth after damp cleaning, while the surface is still slightly moist. This makes the finish smooth and streak-free.
If there are stubborn stains, a mixture of lukewarm water and a few drops of mild dishwashing detergent often helps. The key is to use gentle circular motions and avoid scrubbing too hard.
Can you say whether you usually just wipe the fronts regularly or sometimes do a more intensive cleaning? This would help to better assess the best approach.
Gije52
22 May 2023 12:46
angel schrieb:
Can you say whether you regularly just wipe the fronts or sometimes clean them more intensively? That would help to better assess the optimal approach.
Thanks, angel, that’s a good question. In daily use, I usually just wipe the fronts with a slightly damp microfiber cloth, without any cleaning agents. Once a week, I give them a more thorough cleaning using a mild dish soap solution. It’s possible that I make the cloth a bit too wet, especially when trying to remove tougher stains.
Another point: I’ve noticed that in direct sunlight, it’s particularly noticeable that after drying, really unpleasant streaks remain – almost like water spots or greasy marks, even though I wipe multiple times.
Does this mean I should clean the fronts in the shade or follow up with a completely dry cloth after cleaning? Would a different cloth help? Thanks for any further tips.
kaubi
23 May 2023 07:14
Gije52 schrieb:
I noticed that in direct sunlight it becomes especially noticeable that after drying, really unattractive streaks remain – as if water spots or greasy marks are left behind, even though I wiped multiple times.
This exact observation is very typical and important when cleaning matte surfaces, especially IKEA Metod fronts with their special powder coating. Here is a somewhat more detailed approach that has worked for me:
- First of all, temperature and humidity are crucial because rapid drying in direct sunlight causes water spots or cleaning residues to dry in place, leaving streaks behind.
- Before each cleaning, the microfiber cloth should be freshly washed (without fabric softener!) and well wrung out. This prevents dirt or fibers from transferring onto the front.
- I work with a minimally damp cloth to reduce the cleaning film. Afterwards, I do a second run using only a clean, almost dry cotton or fine microfiber cloth to completely wipe off the surface.
- For greasy or stronger stains, I use a solution of lukewarm water and 2–3 drops of mild dish soap. After application, the surface is kept wet only briefly and immediately wiped with the dry cloth.
- Never clean in direct sunlight; better to clean in the morning or evening when the surface dries more slowly.
- For prevention, I recommend regularly wiping lightly with a care product specifically formulated for matte surfaces; this helps protect the surface and reduces stain formation.
How exactly are your fronts soiled? Just dust, or also fingerprints and food splashes? That would further specify the cleaning intensity and choice of products.
