ᐅ How can I clean matte Ikea Metod cabinet fronts without leaving stains or streaks?
Created on: 1 Jun 2020 09:17
Jugu37
Jugu37
1 Jun 2020 09:17
Some time ago, I bought Ikea Metod kitchen fronts with a matte finish. Unfortunately, when cleaning them, I often notice that despite careful wiping, stains and unwanted streaks remain, which somehow damages or at least makes the matte surface look unattractive.
I usually use a microfiber cloth with some all-purpose cleaner, but somehow the result is never really satisfactory.
My question to you is: How do I properly clean matte Ikea Metod fronts so that no stains or streaks remain and the matte finish is preserved? Are there any special cleaning products or methods that have proven effective?
I look forward to your tips and experiences!
TEBILO
1 Jun 2020 10:45
Hello Jugu37,
To clean matte Ikea Metod fronts as streak- and spot-free as possible, it is important to first understand the surface. The fronts are often melamine-coated, which results in a matte, slightly textured finish that reacts differently to care compared to glossy surfaces.
Here is my detailed suggestion:
- First, wipe dry with a soft, clean microfiber cloth to remove dust and coarse dirt. Do not rub dry but gently wipe, otherwise micro-scratches can form easily.
- For damp cleaning, lukewarm water with a mild, pH-neutral dish soap is suitable, as aggressive cleaners can cause damage. Some users also use a mixture of water and a small splash of vinegar, which can help dissolve grease but should be dosed carefully.
- Cloths should be well wrung out to avoid water spots, and surfaces should be wiped immediately afterward to prevent moisture marks.
- Avoid cleaning tools with abrasive or rough surfaces, including sponges with a scrubbing side.
- For drying, it is best to use a soft, lint-free cotton cloth, gently wiping the surface in circular or straight motions.
- For more stubborn stains, a special plastic cleaner or a mild household cleaner suitable for melamine-coated furniture may help.
- I would like to ask: Do you use special cleaners or only water and all-purpose cleaners? And what type of cloths and sponges do you use?
With some patience and care, the matte appearance should be preserved without streaks or spots.
Alberto51
1 Jun 2020 11:33
I understand how frustrating this can be. Matte surfaces are often quite delicate, and it feels like you’re doing everything right, yet the result still doesn’t look good.
What helped me a lot was always testing the cleaning product first on an inconspicuous spot. I also found it useful to work step by step: starting with just water and a microfiber cloth, then only using a mild cleaner if necessary.
I once tried wiping with too much pressure, which in the end only made the fronts look worse, so please be gentle!
If you’re unsure which cleaners are suitable, I would recommend using less and milder products more often. That way, you also appreciate the material value more.
bupar
1 Jun 2020 14:22
Primer for solving the problem:
- Avoid alkaline cleaning agents, as they can damage the matte melamine coating.
- Use a high-density microfiber cloth that effectively traps dirt without scratching.
- Clean the fronts with distilled or filtered water to prevent mineral deposits that cause streaks.
- Apply cleaning agents sparingly and evenly, avoiding over-wetting.
- Immediately wipe the surface dry afterwards with a clean, dry cloth.
The material of the Ikea Metod fronts is specially coated and sensitive to incorrect care. Specific products from Ikea, such as the "Rengöra" microfiber cloth, are often specially designed for these surfaces.
If the problem recurs, I recommend occasionally treating the fronts with a melamine care oil to improve appearance and protect the surface.
BLAMAU
1 Jun 2020 16:05
Simply clean with a damp microfiber cloth and some mild dish soap, then dry immediately. Do not use harsh cleaners.
LOJOPAR
2 Jun 2020 08:49
I would like to provide a structured guide here, as this topic is often underestimated:
1. Preparation: Make sure the microfiber cloth is truly clean and free of any residues.
2. Cleaning solution: Mix lukewarm water with a small amount of mild dish soap.
3. Cleaning: Thoroughly dampen the cloth, then wring it out almost completely to avoid dripping onto the surface.
4. Application: Wipe the fronts in horizontal strokes to treat the texture evenly.
5. Dry wiping: Use a dry, clean microfiber cloth to carefully dry the surface and prevent streaks.
Common mistakes:
- Using too much cleaning solution
- Leaving moisture on the surface for too long
- Using scouring pads or rough cloths
If streaks appear, polishing again with a high-quality, dry microfiber cloth often helps.
