I have several pieces of furniture in my apartment from Malm (IKEA) with white matte lacquered surfaces. Now I am facing the challenge of cleaning these surfaces without leaving any sanding marks, scratches, or dull spots.
Specifically, I am looking for advice on how to clean Malm surfaces, especially these sensitive matte lacquers, without accidentally causing sanding marks. I want to avoid small scratches from the wrong cleaning products or tools that later become noticeable to the naked eye.
Perhaps you have tips on the right cleaning agents, aids like cloths or sponges, as well as the best methods or cleaning frequency.
Thanks in advance for your expertise!
In general, for matte lacquered surfaces like those on Malm furniture, the finish is very sensitive to mechanical stress. Any mechanical abrasion—such as from rough sponges, scouring agents, or even stiff brushes—can cause tiny scratches or fine sanding marks that become visible under light.
I recommend the following approach:
1. Remove surface dirt using a slightly damp, soft microfiber cloth. The material should not cause abrasion (100% polyester, not cotton, as cotton fibers are often too rough).
2. Cleaning agent: Use a neutral, pH-balanced dishwashing detergent. Avoid harsh cleaners, as they can damage the lacquer layer.
3. Apply light pressure, but do not rub like with sandpaper. Movements should always be gentle, circular, or follow the grain direction.
4. After cleaning, be sure to wipe again with a damp cloth and clean water to remove any residue.
5. For drying, use a very soft microfiber cloth again.
6. If a stain is stubborn, work on it several times with water and a soft cloth rather than scrubbing aggressively.
Regarding cleaning frequency: Regular, mild cleaning prevents stubborn dirt buildup and reduces the need for heavy scrubbing.
One more question for you: Does the piece of furniture already have visible scratches? And are you using common household cleaning products or do you intend to use special products?
bapar schrieb:
One more question for you: Does the piece of furniture already have any visible scratches? And are you using standard household cleaning products or do you plan to use special treatments?Thank you for your detailed response!
The furniture is still quite new; there are no scratches so far. At the moment, I’m using a regular all-purpose cleaner spray, but I’ve noticed that it sometimes leaves slightly shiny spots (probably due to improper cleaning). I haven’t used any special products yet, but I definitely want to avoid harsh chemicals.
The goal is a cleaning method that really protects the surface and doesn’t leave any localized shiny or dull spots.
Maybe there are products recommended by original equipment manufacturers? Or home remedies that work particularly well?
Hello Pisilis,
I completely understand your concerns about the light matte lacquered surfaces. There is a structured approach that I would like to share with you:
1. Cleaning preparation:
Always use a soft microfiber cloth that is dust-free. It’s best to wash it beforehand without fabric softener.
2. Choice of cleaning agent:
A mild dish soap with lukewarm water is usually sufficient. Use just a drop in a full bucket of water, so it is very diluted.
3. Application:
Dip the microfiber cloth into the solution, wring it out well so it is only slightly damp. Clean gently using light, even motions. Avoid scrubbing.
4. Follow-up cleaning:
Always wipe again with a second clean cloth that is only moistened to remove any detergent residues.
5. Drying:
Wipe with a dry microfiber cloth to prevent water spots or streaks.
Important: Avoid sponges with rough surfaces or cloths that shed lint.
Home remedies like a splash of white vinegar in the water are not ideal for lacquered surfaces, as they can damage the finish over time.
You should also avoid all-purpose cleaners containing alcohol or harsh solvents.
If you like, I can recommend special cleaners that are specifically designed for matte lacquered surfaces and do not leave residues.
Does this help for now?
3. Application:
5. Drying:
Pisilis schrieb:
There are no scratches so far. I am currently using a regular all-purpose cleaner spray but notice that occasionally there are slightly shiny spotsThe shiny spots usually come from the cleaner itself, which has not been completely removed. Just wipe again with a damp cloth and then dry it off, and the spots will disappear.
