ᐅ How can I clean Malm furniture without damaging the finish?
Created on: 18 Dec 2022 09:17
Maon42
Maon42
18 Dec 2022 09:17
Hello everyone, I recently bought a few Malm furniture pieces from IKEA and want to clean them properly without damaging the finish. As far as I know, the finish is quite delicate, so I’m wondering which cleaning products and methods are best suited to remove grease stains, dust, or light dirt without leaving streaks or dull spots.
Can someone give me specific advice on what to use – for example, if a slightly damp microfiber cloth is enough, or if I should use special furniture care products? Do household cleaners like dish soap really work well, or are they too harsh? I’m also curious if rough cloths or sponges might cause damage to the Malm finish.
I just want to avoid the beautiful shine or surface being permanently affected after cleaning. Maybe there are some home remedies that have proven effective? I’m looking forward to your tips and experiences!
baupau
18 Dec 2022 09:44
For Malm furniture, a slightly damp microfiber cloth is usually sufficient to protect the finish. It is best to avoid cleaners containing alcohol or solvents. Sponges with a rough surface can damage the finish, so be careful.
Ethan
18 Dec 2022 10:12
Hello Maon42, I completely understand your concern. Malm furniture is usually coated with a thin layer of lacquer, which gives it a nice shine but can be sensitive to harsh cleaners or excessive moisture.
My tip: Use a soft, lint-free microfiber cloth lightly dampened with warm water. For greasy spots, you can carefully add a few drops of mild dish soap to the water, but be sure to wipe it off thoroughly afterwards and never leave the surface wet.
Avoid abrasive cleaners or rough sponges, as they can scratch the lacquer finish.
If you like, you can gently polish the furniture afterwards with a special furniture polish designed for lacquered surfaces – this provides extra protection and helps prevent the finish from dulling quickly.
Feel free to ask if you have any other questions or doubts!
Timmyse36
19 Dec 2022 08:27
I understand the feeling of being afraid to damage your furniture. Your concern is completely valid, as smooth surfaces can quickly look worse if cleaned improperly.
I used to have Malm furniture with a lacquer finish and was initially always uncertain about how to clean it. Fortunately, it has proven effective to never wipe it too wet and to avoid harsh cleaning agents. Sometimes I even feel that a soft microfiber cloth does more for my furniture than various cleaning products. If you’re willing to experiment a bit, try testing first on an inconspicuous spot.
I hope you find a method that feels right for you and helps keep your furniture looking good for a long time. 🙂
If you like, I can also tell you how I occasionally deal with small scratches on lacquered surfaces.
lajudo
19 Dec 2022 09:03
A damp microfiber cloth is always the best choice. For heavier dirt, use a mild soap, then dry thoroughly by rubbing. Do not use harsh cleaners.
labar43
20 Dec 2022 16:38
It’s great that you put so much effort into properly caring for Malm furniture! 😀
I also always use a microfiber cloth, and sometimes I prepare a little dish soap in lukewarm water, just like @Ethan described. Afterwards, I wipe down with clean water and thoroughly dry the furniture to preserve its shine!
I also find it motivating when furniture is cleaned so well that it lasts a long time and always looks fresh 🙂 Keep it up!
