Hello everyone, I have some Malm furniture from IKEA with a matte lacquer finish and would like to know the best way to clean it without damaging the surface. I am especially interested in tips on suitable cleaning products and tools, as well as any special methods to ensure the matte lacquer does not become glossy or develop stains. I would also like to learn how to avoid common cleaning mistakes. Does anyone have experience or recommendations that work well with matte lacquer? Thanks in advance!
FeAndreas117 Aug 2022 10:22Hello Giben2, your question about cleaning Malm furniture with a matte finish is very well asked, as matte surfaces tend to be more sensitive than glossy ones. Generally, I recommend starting by dusting with a soft microfiber cloth. This helps prevent scratches caused by dirt particles.
For damp cleaning, use only lukewarm water, wrung out well to avoid water stains. Alternatively, a mild, pH-neutral cleaner without silicones or waxes is suitable, as these can damage the matte appearance. Make sure the cloth is just damp, not wet.
A common mistake is using harsh cleaning agents like ammonia, alcohol, or abrasives – these can damage the finish and cause the matte effect to disappear. Also, avoid vigorous rubbing, as this can unintentionally polish the matte surface to a shine.
I’m also curious: have you tried special furniture care wipes designed for matte finishes? These are often treated with appropriate care products. If so, how was your experience? And how heavy is the current soiling on the furniture? This information can help provide more specific advice.
Good morning, I understand well that you want to clean matte lacquer furniture carefully because you want to avoid any unsightly marks. I also have Malm dressers, and at first, I was worried that stains might not come off or that the surface would become dull.
In my experience, the key is to be gentle when cleaning and to wipe lightly and frequently rather than less often and more vigorously. I usually use a slightly damp microfiber cloth and avoid chemical cleaners as much as possible. A small drop of dish soap in the water has sometimes helped me when the surfaces were greasy or sticky.
Your topic is very important because matte lacquer can look damaged quickly, but I have also learned that with patience and proper care, you can enjoy it for a long time. If you like, I can share whether I’ve had any special tricks for tougher stains.
FeAndreas1 schrieb:
A common mistake is using aggressive cleaning agents like ammonia, alcohol, or abrasives – these can damage the finish and cause the matte effect to disappear. This is an important point, so here is a simple step-by-step guide on how to properly clean your Malm furniture with a matte finish.
1. Preparation: Dust the furniture with a dry, soft microfiber cloth. Don’t apply pressure; gently wipe across the surface.
2. Damp cleaning: Lightly moisten another microfiber cloth with lukewarm water, optionally adding a drop of mild dish soap. Wring out the cloth well – it should not be wet! Wipe the surface evenly.
3. Dry wiping: Immediately wipe the area with a dry, soft cloth to avoid water spots.
4. Do not use abrasives or harsh cleaning products. Also avoid wax-based furniture creams, as they alter the matte appearance.
5. For stubborn stains: Test a soft cloth lightly dampened with a small amount of alcohol on an inconspicuous area first. Be very sparing and blot gently.
Summary: Gentle care with microfiber cloths, minimal water, no harsh cleaners, and always dry wiping. This preserves the matte finish and keeps your furniture looking nice for a long time.
