ᐅ How do I clean Malm furniture with a delicate finish?
Created on: 11 Feb 2021 08:37
tragu0
tragu0
11 Feb 2021 08:37
I have several Malm furniture pieces from Ikea at home with a very sensitive lacquer finish, and I am unsure how to clean them gently without damaging the lacquer.
Specifically, I would like to know which cleaning agents are suitable and which should definitely be avoided. It would also be helpful to learn about any special techniques or tools that can minimize the risk of micro-scratches or loss of gloss.
I have heard that harsh cleaners and abrasive cloths can be problematic, but I am still looking for concrete recommendations. I would really appreciate any tips specifically for Malm furniture with a lacquered surface!
pilous
11 Feb 2021 09:01
tragu0 schrieb:
Which cleaning products are suitable and which should definitely be avoided
It is essential to know the exact type of finish. Malm furniture is usually coated with a polyurethane or acrylic lacquer, which is resistant to water but sensitive to solvents.
tragu0 schrieb:
special techniques or tools that minimize the risk of micro-scratches
I strongly recommend microfiber cloths, which gently lift dust without rubbing. However, the cloths should be kept clean because dirt particles pose a significant risk. For cleaning liquids, I suggest pH-neutral soaps or cleaners specifically designed for furniture that do not contain waxes or oils that could damage the finish.
Does anyone have reliable experience with common furniture cleaners and Malm? I often doubt advertising claims.
Kukar
11 Feb 2021 09:27
Water with a small amount of dish soap on a soft cloth is usually sufficient. Do not use abrasive sponges or harsh chemicals. Wipe gently and allow to dry thoroughly.
nubar
11 Feb 2021 10:11
Additional tip: For stubborn stains, a mixture of water and mild vinegar (1:10) applied with a soft cloth can help, but only on the affected spot and wiped off immediately.
In general, moisture should not remain on the surface for long, as it can damage the paint finish.
Regular dusting with a dry microfiber cloth also helps to prevent abrasion.
Domau0
12 Feb 2021 07:54
I would like to explore this topic in more detail because delicate finishes, such as those on Malm furniture, have certain characteristics that make cleaning more challenging compared to unfinished or solid wood surfaces.
Basically, Malm furniture is coated with a very thin, transparent lacquer that allows the natural wood tone to show through. This is aesthetically pleasing, but the protective layer is correspondingly thin. Therefore, it is especially important to minimize mechanical stresses that can cause micro-scratches.
Cleaning process step by step:
1. Dry cleaning: First, remove coarse dust and loose dirt particles with a clean, soft microfiber cloth. Do not use paper towels or rough cloths.
2. Damp cleaning: Prepare a bucket with lukewarm water and a mild, pH-neutral cleaning agent (no alcohol, solvents, or oil-based products, as these can dissolve or discolor the lacquer).
3. Wring out the cloths well so they are only slightly damp to avoid soaking the surface. Excess water can seep into edges or gaps and cause damage.
4. Wipe gently, do not rub or scrub.
5. Immediately follow up by wiping with a dry, clean microfiber cloth to avoid moisture marks.
It is also important not to expose the furniture to direct sunlight or high humidity, as excessive UV light can make the lacquer surface porous over time.
Does anyone have experience with specific products based on acrylic or polyurethane lacquers? I am doubtful whether wax removers or similar agents are the best choice.
gadalu
12 Feb 2021 08:32
Domau0 schrieb:
I find it questionable whether wax removers or similar products are the best choice
I agree completely. Wax removers often contain harsh solvents that can cause dents or dull spots on thin paint layers of Malm furniture.
For mechanical cleaning, I recommend using only very soft microfiber cloths with a high thread density. This helps to minimize friction.
My experience is based on laboratory tests of paint samples and long-term studies that clearly demonstrate how sensitive polyurethane (PU) coatings are to chemical substances.
Alongside cleaning, it is also important to ventilate regularly and keep furniture clean to prevent dust and dirt buildup.
