ᐅ How can I clean Malm furniture sustainably without using chemicals?
Created on: 5 Dec 2024 07:34
jepateHello everyone,
I have several Malm furniture pieces from Ikea in my home that I would like to clean as sustainably as possible without using chemical cleaning agents. Since the surfaces are often delicate and I want to avoid harsh substances, I am wondering: How can I clean Malm furniture effectively and sustainably without relying on chemicals?
I am particularly interested in methods that protect wood and veneer, possibly using household remedies or eco-friendly cleaning products that do not cause long-term damage. It would also be helpful to know how to gently remove stains or dirt and care for the surfaces to preserve the furniture.
Does anyone have experience with sustainable cleaning of Malm furniture? Thanks in advance!
Sustainable cleaning of Malm furniture without chemical agents works best using simple household remedies such as diluted vinegar water, olive oil, and a soft microfiber cloth.
Vinegar water removes dirt and kills bacteria without damaging the surface, but the mixture should not be too concentrated; a ratio of about 1:10 with water is recommended. After cleaning, it is advisable to wipe the furniture with a dry cloth to avoid moisture damage.
For maintenance, natural oils like a few drops of olive oil are suitable, as they protect the wood surfaces while keeping them supple. It is important never to apply too much liquid directly to the wood to prevent swelling.
To clean Malm furniture sustainably and without chemicals, I recommend a systematic step-by-step approach:
1. Dry cleaning: First, remove dust using a dust cloth or a soft, dry microfiber cloth. This helps prevent scratches caused by dirt.
2. Damp cleaning: For the actual cleaning, use a mild cleaning solution you prepare yourself, such as a mixture of warm water and a few drops of biodegradable dish soap. Alternatively, as nubar already mentioned, a diluted vinegar-water solution (about 1 part vinegar to 10 parts water) is ideal for dissolving limescale and dirt.
3. Application: Soak a cloth in the solution and wring it out thoroughly until it is only damp. Wipe the furniture with it, avoiding standing moisture on the surfaces. Afterwards, wipe the surfaces again with a dry, soft cloth.
4. Stain treatment: For stubborn stains, small amounts of baking soda can be gently applied locally on a damp cloth. Wipe well to avoid residues.
5. Maintenance: The surface can be cared for every two to three months using a natural wax-based wood care product or linseed oil, provided the manufacturer has not advised against it.
It is important not to use aggressive substances or abrasive sponges, as veneer surfaces can be damaged by such materials.
One more quick question: Are the Malm furniture surfaces lacquered or untreated? This may still be relevant depending on the cleaning method.
Dilen schrieb:
One more quick question: Are the Malm furniture pieces lacquered or untreated surfaces?Thank you for your detailed response! My Malm furniture is the standard lacquered version, meaning it has the glossy, sealed finish. Therefore, I want to avoid the surface becoming dull or looking damaged if I clean too aggressively. Should I be especially careful when cleaning with vinegar water or dish soap?
jepate schrieb:
Do I need to be especially careful when cleaning with vinegar water or dish soap?Yes, caution is necessary when cleaning painted surfaces of Malm furniture. Here are some empirically proven recommendations:
Vinegar water should be heavily diluted and used sparingly, as acetic acid can gradually damage the finish. A dilution ratio of 1:10 to 1:20 is advisable.
Dish soap should be biodegradable and mild, with minimal dosage. The water should never be too hot.
Always use a well-wrung cloth to minimize wet areas. Avoid spraying directly onto the furniture surface.
After cleaning, thoroughly dry the piece with a dry microfiber cloth.
For maintenance, special furniture polish based on silicone or wax is suitable, but without aggressive solvents or alcohol.
The goal is to protect the paint, not to roughen it or allow moisture to penetrate.
