I have several Malm furniture pieces from IKEA in my apartment that I really like, but unfortunately a very stubborn grease stain has formed on the surface of one of the sideboards. The furniture is made of coated material, not solid wood. Of course, I don’t want to damage the piece by using overly aggressive cleaners or scrubbing too hard.
My question is: How can I properly clean Malm furniture when there are grease stains? Which cleaning agents and methods are advisable to remove the grease stain without harming the surface? Are there any home remedies you would recommend, or are special products better?
Maybe someone here has experience and can share some good advice. Thanks in advance for reading and responding!
Thanks in advance to everyone for the helpful tips. One additional question: I have read that sometimes baking soda is recommended as a gentle abrasive. Is it sensible to use it on melamine coating when stains are particularly stubborn? Or is it better to avoid it altogether?
I don’t want to risk dulling or damaging the surface.
fuchen10 schrieb:
Sometimes baking soda is recommended as a mild abrasiveThe topic of baking soda on melamine coatings is a bit sensitive. Essentially, baking soda has a mildly abrasive effect and can therefore damage or dull the smooth surface.
If you can’t remove the stain, I would only try baking soda very carefully and in less visible areas by making a paste with a small amount of water and rubbing gently.
However, if mild methods are not effective, it is better to use specialized melamine cleaners that are specifically designed for these surfaces. These do not contain abrasive or harsh chemicals.
I find the general recommendations for Ikea furniture quite boring by now.
Honestly: grease stains on melamine aren’t the end of the world! If you take such careful care of your furniture that only a mild cleaner will do, you’re living very cautiously.
Why not just be a bit bolder? A gentle alcohol wipe (70%) often works great on grease and doesn’t really damage the surface. Of course, if you want to be on the safe side, you avoid it, but sometimes it’s just more practical.
I think this fear of anything that might be even slightly aggressive is exaggerated.
REOHEINRIC4 Aug 2016 16:27TISON schrieb:
Why not just be a bit more assertive? A gentle alcohol wipe (70%) often works great against greaseThat is a risky recommendation because those alcohol wipes can damage the melamine coating.
The chemical composition of the coating is sensitive to organic solvents, which can cause discoloration and dull spots.
Therefore, I recommend using such products only as a last resort and testing them on inconspicuous areas first.
For the longevity of the furniture, it is better to rely on proven gentle cleaning methods.
