ᐅ How do I clean IKEA PLATSA units when dealing with stubborn stains?
Created on: 15 May 2024 14:37
Lili70
Hello everyone, I have a question that has been on my mind for a few days: What is the best way to clean IKEA Platsa furniture when there are stubborn stains?
Specifically, I’m referring to the white fronts and carcasses, which seem to be sensitive to standard cleaners or where stains don’t come off easily with just soap and water.
I’ve already tried using a mild all-purpose cleaner and a microfiber cloth, but some stains, such as coffee cup rings or small paint splatters, won’t come off.
Maybe someone has experience with special cleaning methods that won’t damage the material? For example, is vinegar or alcohol suitable, or should other products be used?
Thanks in advance for your advice!
Lili70
16 May 2024 09:13
Thank you for your tips so far!
[@Surela]
Yes, the fronts have a melamine resin coating (I don’t think it’s a laminate film, as far as I can tell). The stains are mostly coffee and coffee ring marks, plus a few tiny acrylic paint splatters from some craftwork that unfortunately missed the target.
[@RENMA]
I appreciate the advice about wiping again and drying promptly—I hadn’t paid attention to that before.
I will carefully try using melamine sponges and then polish with a clean cloth afterwards.
Would it also help to let the stains soak with lukewarm water before cleaning? Or should that be avoided to prevent the surface from swelling?
Looking forward to more tips!
Ramon4
16 May 2024 10:27
Hello Lili70,
It’s a good idea to let stains soak briefly with lukewarm water before treatment, especially with coffee or food stains.
Important:
- Use a soft cloth that is only slightly dampened, not too wet.
- Avoid standing water on the surface, as the melamine coating does not tolerate prolonged moisture.
- After soaking, gently wipe the stain off with light pressure.
Overall, the procedure should be done quickly to protect the surface.
If acrylic paint is stubborn, you can try carefully treating it with a cotton swab and some isopropyl alcohol, but always spot test and proceed with caution.
dijan
16 May 2024 17:45
Lili70 schrieb:
Would it also help to let the stains soak a little with lukewarm water before cleaning? Or should that be avoided to prevent the surface from swelling?
I think soaking with a damp cloth often works wonders – but always wipe off quickly!
If you then gently use a slightly dampened melamine foam sponge, you can remove almost anything.
And hey – don’t worry, Platsa usually handles more than you’d expect if you’re gentle. Don’t get discouraged!
