ᐅ How can I clean IKEA Metod glass cabinet doors without leaving streaks?
Created on: 20 Apr 2015 08:47
Fralo
Fralo
20 Apr 2015 08:47
Hello everyone, I have a rather specific question about cleaning IKEA Metod kitchen fronts with glass: How can I get the glass fronts completely streak-free? I have tried various cleaning products, but there are always unpleasant streaks left, especially when I wipe the fronts dry or only use glass cleaner. I am particularly interested in which cleaning techniques and tools work best without damaging the sensitive surface – and if there are any tips to keep in mind when drying. Are there any special tricks or products that have proven effective for Metod glass fronts? I look forward to your experiences and advice!
LENNAU
20 Apr 2015 09:33
Fralo schrieb:
How can I get glass fronts really streak-free? I have already tried different cleaning agents, but there are always unpleasant streaks left behind.
Hello Fralo,
I know your problem well, as glass fronts can be quite tricky. The key is using the right cleaning product and technique. It’s best to use a mild glass cleaner without ammonia or strong alcohol content to avoid damaging the surfaces.
- First, dry dust off with a microfiber cloth.
- Then spray the glass cleaner, but not too much—less is more.
- Polish with a second clean microfiber cloth until no streaks are visible.
Cotton cloths are also good for drying but must be truly lint-free. Sometimes, lightly dampening the microfiber cloth beforehand helps since it prevents friction heat that can cause streaks.
Another method to try: mix a little water with a few drops of dish soap to clean the glass front, then wipe again with a vinegar-water solution (about 1:1 mix with water). This removes greasy residues, and the vinegar helps prevent streaks.
I hope these tips help you!
emmaju
20 Apr 2015 11:02
Fralo schrieb:
I am especially interested in which cleaning methods and aids work best without damaging the delicate surface
Hello Fralo,
Your concerns about the sensitivity are justified. The Metod glass fronts are made of tempered glass, but the frame is usually plastic or wood, which can react poorly to harsh cleaners.
For my Metod fronts, I always follow this procedure:
- Never use abrasive cleaners
- Use a glass cleaner with a mild alcohol content or a mixture of 50% water and 50% white vinegar with a drop of dish soap
- Do not spray directly onto the surface; apply to the cloth instead
- After cleaning, immediately wipe with a dry, lint-free cloth
If you follow this, streaks will be minimized and the fronts will stay nice. Another tip: clean regularly, so fewer stubborn deposits build up that are harder to remove.
Good luck!
Johnathon
21 Apr 2015 07:16
Fralo schrieb:
How can I get the glass fronts truly streak-free? I’ve already tried various cleaning products, but there are always unsightly streaks left behind, especially when I wipe the fronts dry or only use glass cleaner.
Hello Fralo,
since you’ve already tried several methods, here is a detailed explanation considering the material and surface structure of IKEA Metod glass fronts:
1. Material: The glass fronts are usually made of tempered safety glass on the front side, surrounded by a flush frame made of MDF or plastic. Typically, the frame is more sensitive than the glass itself.
2. Choice of cleaning agent: Alcohol-based glass cleaners can evaporate quickly and leave streaks. Ammonia-containing products should also be avoided because they can damage plastics. Ideally, use neutral cleaners or special glass cleaners without additives.
3. Technique:
- Always remove dry dirt (dust, larger particles) first using a lint-free cloth,
- Do not spray the cleaner directly over a large area; instead, apply it lightly onto a microfiber cloth (this helps prevent drips and spots),
- Clean with circular motions,
- Follow by polishing with a clean, dry microfiber cloth,
- It is essential that the cloth is truly clean. Dirty cloths cause streaks.
4. Drying: Ideally, dry the surface immediately because dried droplets often cause streaking.
5. Extras:
- A slightly damp cloth for polishing can also help,
- For tougher stains, a mixture of warm water with a few drops of dish soap is effective.
- One more tip: Avoid cleaning in direct sunlight, as this promotes streak formation.
Maybe you can also share details about the room temperature or the cleaning tools you are using, so I can assist you more precisely?
Fralo
21 Apr 2015 12:59
Johnathon schrieb:
Maybe you could also share some information about the room temperature or your cleaning tools so I can assist you more precisely?
Thank you for the detailed post! The room temperature is usually between 20 and 22 degrees Celsius (68 and 72°F), with no direct sunlight on the surfaces. I have mostly used commercial glass cleaner containing alcohol and wiped the fronts dry afterward with a microfiber cloth. This often results in those annoying streaks.
I will definitely try your tip of gently polishing with a slightly damp cloth and spray the glass cleaner onto the cloth rather than directly on the glass surface.
Do you have any other recommendations, for example regarding the order of cleaning steps or the type of cleaning cloths? Some people say that cotton is better than microfiber. Is that true?
nikian
22 Apr 2015 10:44
Fralo schrieb:
Do you have any other suggestions, for example regarding the order of the cleaning steps or the material of the cleaning cloths? Some say that cotton is better than microfiber. Is that true?
Microfiber cloths are definitely better for glass. They are designed to pick up dust and dirt more effectively without leaving scratches. Cotton can leave lint, which shows up as streaks.
Order:
- First, wipe off dust with a dry microfiber cloth
- Apply cleaning solution to the cloth, never spray directly onto the glass
- Clean using circular motions
- Gently dry and polish with a dry microfiber cloth
It’s best to use two different microfiber cloths: one damp and one dry.
Also, genuine leather window cloths can be helpful – they absorb liquid well and leave no streaks, but are more expensive.
And again: never clean in direct sunlight, as this causes too rapid drying and streaks.
