ᐅ How do I clean IKEA BESTA units when dealing with stubborn stains?
Created on: 30 Sep 2024 08:23
Binileo
I have an IKEA Besta sideboard that unfortunately has developed some stubborn stains on the surface. The affected area is the melamine-coated front, which can be somewhat delicate. Specifically, these are stains that appear to have dried in for weeks—most likely food residues or drink marks.
I’m looking for a cleaning method that is as gentle as possible but still effective at removing the stains while protecting the surface. Which household remedies or specialized cleaning products would you recommend? Are there any chemicals I should avoid to prevent damage to the melamine coating?
I would greatly appreciate any experiences, tips, or detailed instructions, as I want to proceed carefully to avoid damaging the furniture.
Thank you in advance!
blapau
30 Sep 2024 17:50
I would like to add a few tips to help avoid permanent damage:
- Please do not use abrasive sponges or steel wool, as the melamine coating can easily get scratched.
- Avoid cleaning agents containing bleach, as they can alter the color.
- After cleaning, the surface should be thoroughly dried to prevent moisture damage.
- A special melamine cleaner can be used for very stubborn stains, but these are not inexpensive.
For stains from coffee and fruit juice: It often helps to moisten the stain with a damp cloth and gently rub in a little baking soda – then wipe off thoroughly.
If you have a particularly deep-seated stain, the surface may appear slightly dull in that area. In that case, a fine polishing pad (specifically for plastics) can help, but use caution when applying!
DUVIN
1 Oct 2024 08:16
Use lukewarm water with a small amount of dish soap for cleaning. For stubborn stains, apply a paste made of baking soda and water, let it sit for a short time, then gently wipe off. Never use strong chemicals or abrasive cleaners.
Jensson
1 Oct 2024 10:43
Binileo schrieb:
It is the melamine-coated surface, which is often somewhat delicate
To add to my instructions: If you want to be on the safe side, you can use special cleaning products designed for melamine. Look for labels such as “mild” or “pH-neutral.”
When using such cleaners, always work with a soft cloth and rinse thoroughly with clean water.
Also: Avoid direct sunlight after cleaning, as wet surfaces can be damaged more quickly by heat.
I hope this helps you with your maintenance. Good luck!
