ᐅ How do I clean IKEA BESTA units when dealing with stubborn stains?
Created on: 30 Sep 2024 08:23
BinileoHello everyone,
I have an IKEA Besta sideboard that unfortunately has developed some stubborn stains on the surface. The affected area is the melamine-coated front, which can be somewhat delicate. Specifically, these are stains that appear to have dried in for weeks—most likely food residues or drink marks.
I’m looking for a cleaning method that is as gentle as possible but still effective at removing the stains while protecting the surface. Which household remedies or specialized cleaning products would you recommend? Are there any chemicals I should avoid to prevent damage to the melamine coating?
I would greatly appreciate any experiences, tips, or detailed instructions, as I want to proceed carefully to avoid damaging the furniture.
Thank you in advance!
Hey Binileo,
thanks for your detailed question! IKEA BESTA furniture is quite sturdy, but for stubborn stains, a combination of patience and the right technique often helps. I recommend first wiping the surface with a soft, slightly damp cloth and some mild soapy water – rub a bit longer if needed, but not too hard to avoid scratching the finish.
For particularly stubborn spots, I like to use a paste made from baking soda and water. Apply it gently to the stains, let it sit for a short time, then wipe it off with a damp cloth. Important: don’t use too much moisture – melamine doesn’t respond well to excessive wetness.
And don’t worry, this method usually removes most stains without damaging your BESTA. 😉 Good luck and feel free to share what worked for you!
Hello Binileo,
I’d like to add a small step-by-step guide that helped me clean melamine-coated surfaces like those on IKEA BESTA:
- Step 1: First, remove dust and loose dirt with a microfiber cloth.
- Step 2: Prepare a mild cleaning solution (e.g., a few drops of dish soap in lukewarm water).
- Step 3: Slightly dampen a cloth—make sure the water does not drip.
- Step 4: Gently wipe the stains without applying strong pressure.
- Step 5: For stubborn stains, you can try using a rubber eraser (e.g., a classic “impression eraser”)—very gently and with circular motions.
- Step 6: Finally, wipe the surface with a dry cloth.
Common mistakes are using too much moisture or abrasive cleaners that can scratch the surface.
If you like, I can share a few tips on special cleaners for melamine that won’t damage the finish.
Hello Binileo,
I think your question is very well formulated because it clearly describes the surface and the type of damage involved. Since I work a lot with furniture materials, I would like to give you a detailed answer.
IKEA BESTA furniture does indeed have melamine resin-coated surfaces, which are generally very resistant to scratches and moisture, but they can be damaged by aggressive cleaning agents or sharp tools.
For dried-on stains, I recommend the following approach:
- First, use lukewarm water with a few drops of mild dish soap. A soft sponge or microfiber cloth is essential.
- If the stains remain, you can try a mixture of vinegar essence (very diluted, about 1 part vinegar essence to 10 parts water) on a damp cloth. Vinegar helps remove lime or water deposits, but the surface should then be thoroughly wiped with water to avoid residue.
- Alternatively, isopropyl alcohol (rubbing alcohol) on a lint-free cloth can be used to remove greasy or sticky stains. Do not spray directly onto the surface; always dampen the cloth first.
Important: Test each method on an inconspicuous area first to avoid discoloration.
I am curious: What kind of stains are they exactly? (e.g., grease, ink, coffee) Sometimes this leads to very different approaches.
I look forward to your feedback!
Filippo schrieb:
I’m curious: What type of stains are they exactly? (e.g., grease, ink, coffee) Sometimes different stains require completely different approaches.Thanks, Filippo, for your question!
The stains are mainly from dried coffee and partly from a dark fruit juice that apparently spilled and wasn’t wiped off immediately. The surfaces are satin matte white, so quite sensitive to abrasion or yellowing.
So far, I’ve had the problem that regular glass cleaners don’t really remove these stains, and chemical cleaners always seem a bit “too strong.” I’m looking for the right balance between effectiveness and preserving the surface.
Looking forward to more tips!
Binileo schrieb:
The stains are mainly from dried coffee and partly from a dark fruit juiceAh, I know those stains all too well! Coffee and fruit juice can be stubborn, but they’re nothing you can’t remove.
I’d recommend trying a small amount of white wine vinegar in warm water—about one tablespoon per 500ml (17 fl oz). Simply apply it with a microfiber cloth, let it sit briefly, then gently wipe it off. After that, apply a little dish soap diluted in water and wipe again.
If the smell bothers you, just wipe with clean water afterward and dry the surface.
It worked wonders for me—and the best part is that vinegar isn’t harsh on the finish as long as you don’t leave it on too long.
