ᐅ What is the most effective way to clean IKEA BESTA units?
Created on: 6 Dec 2024 18:04
dalibor
dalibor
6 Dec 2024 18:04
I recently assembled an IKEA Besta shelving unit and now want to clean it effectively. Since the Besta system is made from different materials, such as melamine-coated surfaces and glass fronts, I’m unsure which cleaning products and methods are the gentlest yet most efficient. I’m particularly interested in how to
- reliably remove fingerprints and dust without damaging the coating,
- which products work well for stains on the glass fronts,
- and whether different approaches are needed for the plastic or MDF components.
Does anyone have experience or tips on how to best maintain the Besta so it still looks like new after a long time? Which cleaning products are recommended or better avoided?
Thanks in advance for your detailed responses!
Filippo
6 Dec 2024 19:37
Hello dalibor,
your concern is very well formulated, as the IKEA BESTA indeed combines different surface materials, so distinguishing between them when cleaning definitely makes sense. I would like to describe a comprehensive approach, including some small tips to maximize the lifespan of the surfaces:
- Dust: It is best to regularly remove dust with a microfiber cloth. These cloths are smooth enough not to cause scratches and effectively pick up dust without spreading it around.
- Melamine surfaces (most cabinet sides and doors): Avoid using harsh scouring agents here! A neutral all-purpose cleaner is sufficient. I recommend spraying the cleaner onto the cloth and then wiping the surface, not spraying directly on the furniture. Stubborn stains can be treated with a mild dish soap and water mixture. Important: Do not leave the surface wet; wipe immediately and then dry to prevent water spots or swelling.
- Glass fronts: These can be cleaned well with glass cleaner or a mixture of water and a little vinegar. Again, avoid aggressive chemical agents and paper towels, as they can cause fine scratches. Microfiber cloths are better.
- Plastic strips and profiles: These can be cleaned with a mild cleaning agent and a soft cloth, but be careful not to make them too wet, similar to MDF.
Since you explicitly mention the risk of damage to the melamine coating: you should avoid sharp scratching tools, scouring pads, or solvents like acetone, as they can permanently damage the surface.
Two questions for you: What does your current cleaning routine look like? Have you already tried certain cleaning agents? And how often do you plan to clean the BESTA, e.g., weekly or less often?
This way, we can tailor advice more specifically to your situation!
Davidleo
6 Dec 2024 20:51
Hey dalibor and everyone else,
I love the BESTA – and of course, it should stay clean! 😊
From my experience, a good glass cleaner works wonders for the glass fronts! If something sticks or there are fingerprints, just spray lightly and wipe with a microfiber cloth – sparkling clean!
For the other surfaces, I usually use warm water with a bit of dish soap. You don’t usually need to scrub hard, and I do this about once a week to keep everything fresh and clean.
One more tip: definitely avoid harsh cleaners or using too much water. The BESTA is sturdy, but too much moisture can be a problem, especially around the edges.
So, get to your cabinet and good luck! If you do this regularly, your BESTA will look like new for a long time! 👍
likuken
7 Dec 2024 08:23
Dalibor schrieb:
Does anyone have experience or tips on how to best maintain the BESTA so that it still looks like new even after a long time?
It’s interesting how many people here seem to think you need special cleaning methods for such a standard piece of furniture. The IKEA BESTA isn’t an antique dresser with delicate finishes.
Why not just use some soapy water and a sponge? Like we used to do with kitchen cabinets. Let’s not make it more complicated than it is! It’s sturdy enough, even if you occasionally use a slightly abrasive cloth.
Honestly, sometimes I feel that people tend to overdo furniture care. Avoiding “aggressive” cleaners sounds almost like the furniture has to be wrapped in cotton wool.
What do you think? Shouldn’t we sometimes be less delicate and put the BESTA through a bit more wear?
Of course, nothing extreme like a grinder, but giving it a good scrub every now and then isn’t a crime, right?
Nabla64
7 Dec 2024 11:56
Hello dalibor, hello everyone,
I would like to provide a structured overview of how to clean and maintain IKEA BESTA most effectively to ensure its longevity:
1. Preparation:
- Remove dust from the furniture using a soft microfiber cloth or a duster.
2. Cleaning the melamine surfaces:
- Mix a mild dishwashing detergent in lukewarm water.
- Wipe the surface with a well-wrung soft cloth.
- Treat stubborn stains with a damp cloth applying a bit more pressure.
- Finally, wipe down with a dry cloth to avoid water spots and swelling.
3. Glass fronts:
- Use a glass cleaner or a vinegar-water solution (1:1).
- A lint-free microfiber cloth is ideal.
- Wipe gently to prevent scratches.
4. Edges and handles:
- Clean with a damp cloth; for heavier dirt, use mild soapy water.
- Avoid sharp sponges or abrasive cleaners.
5. General tips:
- Do not use harsh chemicals (e.g., acetone, bleach).
- Avoid abrasive sponges.
In summary, the perfect combination of mild cleaning, gentle application, and regular dusting is the key to success. This keeps the surfaces free of damage and preserves the material’s stable structure.
If anyone has specific stains (e.g., adhesive residue or grease spots), I am happy to provide more detailed advice.
likuken schrieb:
Why not just use some soapy water and a sponge? Like we used to with kitchen furniture.
I basically agree, but with MDF components and melamine coatings, you need to be careful with moisture. I would rather not recommend a wet, dripping sponge, as moisture can cause the wood to swell.
