ᐅ How can I clean Billy shelves when they have stubborn dirt?
Created on: 1 Jan 2020 09:12
klodi
Hello everyone, I have a somewhat specific problem with my Billy shelves from IKEA: In some corners and along the edges, stubborn dirt has accumulated that cannot be easily removed with a damp cloth or standard cleaning products.
My question: What is the best way to clean Billy shelves with stubborn dirt without damaging the surface? Are there any proven techniques or home remedies you would recommend, especially for these typical white laminated surfaces? I would appreciate tips on how to thoroughly and gently clean the shelves, even when the dirt is really dried in.
tangi
2 Jan 2020 08:19
This helps with such residues: Steam!
A handheld steam cleaner is ideal for the edges and corners of shelves. The hot steam loosens dirt and deposits while also disinfecting. Afterwards, wipe down with a dry microfiber cloth.
This combination has already helped me remove many stubborn spots without damaging the surface.
Z
zartra
2 Jan 2020 10:42
First, dust off dry. Then clean with a mild detergent solution and a soft cloth. For stains, use a baking soda paste. Wipe again with a damp cloth, then dry.
EDWARD0
2 Jan 2020 11:05
If the dirt is very stubborn: spray shaving foam, let it sit for a short time, then wipe it off. This often works great on laminate surfaces.
pinJustin
2 Jan 2020 12:30
I do not recommend using harsh cleaners. Instead, use a soft cloth and a gentle cleaner. Test vinegar water carefully if there are no sensitive areas; otherwise, use a baking soda solution.
GLALEO
2 Jan 2020 16:25
EDWARD0 schrieb:
Spray shaving foam, let it sit briefly, then wipe off.
That’s brilliant! I’ve never tried that before, thanks! I’ll try it right away on my own Billy shelf 🙂
Samuel
3 Jan 2020 09:14
One more tip from me: If you notice the dirt changing color while scrubbing, you should change the water quickly to prevent the stain from spreading through the water.
Also, especially with white Billy shelves, good lighting helps to clearly see all the dirty spots – so you won’t miss a single corner! 😉
