ᐅ How can I make MALM furniture childproof and secure?
Created on: 21 Aug 2022 19:43
REDON56
REDON56
21 Aug 2022 19:43
I have several MALM furniture pieces from IKEA at home that I would like to stabilize to make them child-friendly. I have noticed that especially drawer chests or smaller shelving units can tip over easily when children are playing, which can be very dangerous. I am specifically looking for proven methods to securely attach these pieces to the wall or within the room without completely ruining the appearance or making the furniture unusable. Are there any child safety kits you would recommend? Or are custom solutions using brackets or additional supports better? I am also interested if anyone has experience with wall mounting on different wall types (plasterboard/drywall, concrete, wood), as I don’t want to drill without proper guidance. What tips do you have for securing MALM furniture in a sustainable and child-safe way? Thank you in advance for all detailed answers!
sinhau
21 Aug 2022 20:11
Hello REDON56,
Regarding your topic "How do I childproof MALM furniture to make it stable?" I would like to start with a brief overview: The most important aspects are wall attachment, internal reinforcement, and child-safe drawer locks.
1. Wall attachment: IKEA often provides anti-tip fittings that are fixed to both the furniture and the wall. Ideally, first determine the material of your wall. For drywall (plasterboard), it is best to use special cavity anchors that distribute the weight effectively. For concrete or solid masonry, universal anchors and appropriate screws are suitable.
2. Internal reinforcement: Furniture can tip over if something inside the drawers causes imbalance. A practical solution is to avoid overloading the drawers and, if possible, concentrate heavier items at the bottom. Some people use additional clamp strips or small brackets inside the furniture to increase stability.
3. Child safety: There are locks and stoppers that prevent unintended opening of drawers. This is especially useful for MALM dressers, as open drawers can act as levers.
Common mistakes: Many drill holes incorrectly or use inappropriate anchors. Be sure to select anchors carefully according to the wall type and avoid tightening screws too much to prevent damage to the furniture.
In summary: Always secure your furniture to the wall first using suitable anchors and anti-tip brackets, and complement this with child-safe drawer protection systems. I hope this helps you!
KAUDRA62
21 Aug 2022 21:02
Hey REDON56,
your concern sounds very reasonable! Honestly, nobody wants children to accidentally tip over a piece of furniture and get hurt. 🙂
I have always secured our MALM dressers with the original IKEA anti-tip brackets, which are straightforward and hold very firmly—provided you use the correct wall anchors for your wall type.
A little tip: if you don’t want to drill, you can use so-called anti-tip straps that you can tension between the furniture and the wall. They also hold quite well and are quick to install.
I also find it helpful to distribute the weight deliberately. Heavy items go at the bottom, lighter ones on top; otherwise, the whole setup becomes unstable.
Regarding "
sinhau schrieb:
avoid unsuitable wall anchors
", I agree—better to do it right once than to fix it twice. Good luck, and if you need more tips, just ask! 😉
Blavin
22 Aug 2022 08:37
For factual clarification:
The tip-over restraint kits from IKEA are generally suitable for securely fastening MALM furniture to the wall. These consist of a metal strap or plastic belt that is attached to both the furniture and the wall rail.
When drilling into different wall materials, the following applies:
- Concrete/masonry: Use nylon expansion anchors with appropriate screws.
- Plasterboard walls (drywall): Cavity anchors (e.g., toggle anchors or metal expansion anchors) are recommended here, as standard anchors will not hold.
Note: The attachment should be made in the center of the wall or onto load-bearing elements, not just the plasterboard panel. If there is no load-bearing stud behind the wall, special anchors are required.
Additionally, it is advisable not to overload the furniture and to store heavy items in the lower drawer or at floor level to reduce the risk of tipping.
Drawer locks also prevent lateral pulling out by children, which further enhances stability.
These guidelines comply with common safety standards, and a mounting instruction sheet from IKEA is included with every MALM tip-over restraint kit.
Proper installation is essential to avoid injuries.
Rensan3
22 Aug 2022 09:15
Simply use the provided tilt restraints from IKEA and attach them to the wall.
Choose wall anchors suitable for the wall material. For drywall, use hollow wall anchors.
Place heavy items at the bottom to prevent the furniture from tipping over easily.
karlau
22 Aug 2022 10:49
Rensan3 schrieb:
Just use the supplied anti-tip devices from IKEA and attach them to the wall.
Well, it’s not always that simple. I think people often underestimate how much wiggle room children have when they have unsupervised access to such furniture. In my opinion, the “supplied anti-tip devices” are half-hearted if you want to secure things properly for kids.
I have installed everything possible – from additional brackets inside, non-slip mats underneath, to custom-made wall anchors. My point is: standard solutions are not enough because kids are quite creative when it comes to finding leverage mechanisms.
So anyone who thinks “oh, the IKEA set is enough” is often mistaken and taking a risk. It’s worth approaching this with a bit more imagination and structural effort.
Of course, you shouldn’t turn the furniture into a tower, but to me, “child-friendly” also means minimizing risk tolerance as much as possible – and that’s barely achieved with a simple screw.
Do you have other opinions on this?
