ᐅ How can I childproof Ikea Besta drawers easily without much effort?
Created on: 14 Jan 2021 08:23
ArwedHello everyone,
I hope you can help me with my request. I have several Ikea Besta drawers at home and would like to make them childproof. I am looking for a solution that is easy to implement—so no complex modifications or special tools. The drawers should be securely locked to prevent small children from pulling out the contents, but it should also remain easy for adults to operate.
Does anyone have experience with drawers like these and can recommend methods that are simple to apply yet effective? I would appreciate any tips and tricks, including suggestions for products or DIY solutions.
I find the question very precisely formulated, which is a good starting point to receive specific suggestions. However, to better understand the requirements: What exactly do you mean by "without much effort"? A secure child safety lock usually involves some installation, as simple adhesive solutions often don’t last long.
So you’re looking for a solution that is sturdy but easy to install, right? In that case, I would recommend magnetic child safety locks installed on the inside. These are invisible from the outside, prevent unauthorized opening, and only require a small hole for the mounting clip.
However, I wonder how frequently the drawers are used and whether it is necessary for the lock to be completely intuitive for all adults. Magnetic systems often require a special magnetic key. A compromise could be an internal latch mechanism that can be installed with minimal tools.
I wonder if these "childproof" drawers are really necessary – aren’t children naturally curious and meant to explore? However, if the effort should be minimal and still effective, I see two main challenges: safety versus convenience.
Simply using adhesive won’t hold, and magnetic locks require a key that can easily get lost.
Perhaps a simple latch made of wood or metal that can be manually engaged and disengaged when needed would be enough? It would be inexpensive, durable, and easy to implement.
Just a thought: sometimes it might be better to teach children what is off-limits instead of relying on physical locks.
Of course, it’s different with toddlers. Could you provide more details about the children’s ages? That way, more targeted advice can be offered.
Linavin schrieb:
So you want a solution that is sturdy but easy to install, right?Exactly, that sums it up well. The drawers are used every day, so the lock shouldn’t be complicated.
LIELCHEN schrieb:
Can you give more information about the children’s ages?Our daughter is just under 2 years old. So it’s definitely not the stage for complex rules she can understand; the lock really needs to physically prevent her from opening the drawers.
LIELCHEN schrieb:
Just sticking it on won’t hold, and magnetic locks require a key that tends to get lost.I agree – I’ve already thought about clamp mechanisms that can be installed without drilling. Do you have any specific examples? DIY options welcome.
A relatively simple yet effective method is to use clip-on locking systems specifically designed for Ikea furniture. These are typically installed without drilling and work with a spring mechanism that locks the drawer but can be easily opened by an adult with a press.
- Advantage: No large tools required
- Advantage: Minimally visible and removable without residue
- Disadvantage: Can wear out with frequent use, so regular checks are recommended
A good alternative is magnetic child locks, as suggested by Linavin. They are somewhat more complex to install but provide greater security.
I recommend checking product compatibility with Ikea Besta before purchasing, as some locks are designed for box furniture and others for drawer fronts.
PECLARISSA15 Jan 2021 09:55I tested a few of these child safety locks at home—including clamp and magnetic types—and I can say that the clamp locks work really well! Kids usually dislike them because they require a certain amount of pressure or a pinching motion, which little ones can’t manage. For us adults, though, it’s very easy.
The effort involved is minimal since you don’t need to drill anything, and in case of emergency, the lock can be quickly removed or replaced.
I get the impression this is the perfect balance between effort and safety. And honestly, it’s worth spending a bit of time researching before buying impulsively.
