Hello everyone, I recently purchased the Ikea Brimnes furniture piece and would like to modify its surface to better suit my room design. My question is: What are the best methods to alter or visually enhance the surface of BRIMNES (e.g., doors, drawer fronts, side panels)? I am especially interested in techniques like painting, applying adhesive foil, or possibly replacing the fronts. Are there any specific considerations regarding the material that I should keep in mind to achieve a durable and good-quality result? I prefer not to use expensive specialty materials, but rather to get creative on my own with simple methods. I would appreciate any tips, advice on preparation, or products that work well.
Elijah42 schrieb:
I would recommend lightly sanding the surface first to help paint or foil adhere better.Unfortunately, I have read that some melamine-coated surfaces can be easily damaged by sanding. Is there a recommended method to sand safely without penetrating the coating? Or is it usually enough to just lightly sand with very fine sandpaper?
Sanding should always be done with very fine sandpaper (e.g., grit 240 or finer) to roughen only the top gloss layer without sanding through the melamine coating.
A gentle sanding with light pressure is sufficient to improve adhesion.
Alternatively, there are special primers that work very well directly on smooth surfaces, making sanding unnecessary.
nubar schrieb:
Alternatively, there are special primers that can achieve excellent adhesion on smooth surfaces without the need for sanding.That sounds interesting – could you recommend a product name or specific type of primer that works well on melamine or plastic surfaces like those on BRIMNES? I would like to avoid sanding if technically feasible. Thanks in advance!
