ᐅ How can I carefully move IKEA BRIMNES furniture through narrow staircases?
Created on: 8 Jan 2020 09:23
ellinaHello everyone,
I am currently facing the challenge of moving my new IKEA Brimnes furniture – specifically a bed frame and a wardrobe – through a very narrow staircase in my older building. The staircase is quite narrow and has several 90-degree turns. I’m concerned that the furniture could get damaged during the move, as the BRIMNES series is mostly made of coated particleboard, which is sensitive to scratches and bumps.
Does anyone have experience or recommend strategies for transporting furniture gently and without damage through such tight staircases? I’m particularly interested in the best way to disassemble, pack, or carry the furniture parts to prevent any damage. Are there any tools or techniques that might help improve protection?
I look forward to your tips and advice!
Hey ellina,
great that you described the topic so thoroughly! BRIMNES furniture is really nice, but yes, the surfaces are delicate, especially if you have a narrow staircase. I can only agree: stay calm and prepare well! 😄
What helped me:
- Completely disassemble the furniture, not just roughly, but take apart every piece.
- Wrap all larger parts with blankets or special furniture pads. If you don’t have furniture pads, a thick blanket or even bubble wrap works great to protect against scratches.
- When dealing with corners: try to carry the pieces upright or slightly tilted – this helps avoid doors hitting stair steps and walls.
- Tools: a carrying strap (available cheaply) makes transport much easier and reduces slipping on the way.
Sometimes it’s really worth getting some help – with two or three people, it’s much easier to maneuver a heavy piece. Keep your head up, you’ve got this! 🚀
What helped me:
miAlessio8 Jan 2020 14:07Hello ellina,
I would like to add to vinpau’s advice with a more structured approach to ensure nothing goes wrong when transporting the IKEA BRIMNES furniture through a narrow staircase.
1. Disassembly:
- Take the furniture apart as much as possible without compromising the fit and stability.
- Unscrew drawers and doors – these often help reduce weight and allow for more flexible maneuvering through tight spaces.
2. Protective Measures:
- Pad all edges and corners; special edge protectors work well for this.
- Blankets, bubble wrap, or moving blankets are important to protect delicate surfaces.
3. Transport Technique:
- Carry the pieces standing on their long side whenever possible to minimize contact areas with walls and steps.
- For right-angled stairs, tilt the furniture slightly to better navigate the turn.
- Make sure no one steps backward during turning – coordination and communication among helpers are crucial.
4. Tools:
- Carrying straps are very helpful, especially when there are only two people.
- Thin felt glides might also be useful if parts need to be slid across the floor.
If you can fully disassemble the wardrobe, that helps enormously. If not, at least remove all doors and drawers completely.
In summary: preparation and protection, slow and coordinated carrying, and the right tools are your best allies. If you want, I can also provide tips on safely reassembling the furniture if you encounter any problems.
1. Disassembly:
4. Tools:
ellina,
from a practical standpoint, the following is important when transporting IKEA BRIMNES furniture through narrow staircases:
- Consider material properties: BRIMNES furniture is made of melamine-coated particleboard, which is sensitive to moisture and mechanical stress.
- To avoid damage:
- Fully disassemble all removable parts.
- Wrap individual pieces with protective materials such as blankets or bubble wrap.
- Handle carefully, especially around edges and corners.
- When carrying, keep furniture pieces as vertical as possible to prevent scratching surfaces against stair railings or walls.
- Measure the staircase in advance: check all dimensions – stair width, landing heights, and turning radii – to assess the furniture pieces properly.
- Using professional carrying aids (carrying straps) or at least two strong helpers is recommended.
Be cautious when tilting the panels – this can cause stress leading to cracks. Ideally, carry furniture upright and slide it carefully through narrow passages.
Thorough preparation combined with deliberate, steady movements during transport minimizes potential damage.
- To avoid damage:
Demetrius9 Jan 2020 20:49ellina schrieb:
Does anyone have experience or recommendable strategies for moving furniture carefully and without damage through such narrow staircases?I can relate to that very well; I was quite worried myself when I had to move my BRIMNES furniture through a similar stairwell. The feeling that something could get damaged definitely takes away some of the joy before assembly.
What helped me was allowing plenty of time for preparation and avoiding working under pressure. Organizing the helpers was also important – if someone feels unsure, it can slow down the process or put the furniture at risk.
It’s also crucial to constantly communicate about how the furniture is being moved and if there are any obstacles. Supporting each other and moving cautiously is very helpful.
In case it gets too tight: I tried to break down the larger panels into smaller parts as much as possible, and I carefully labeled all screws and small components so that nothing would get lost during assembly.
Have you had similar experiences? How did you manage the stress of transporting furniture through staircases?
Demetrius schrieb:
The feeling that something might break takes away some of the joy before assembly.Exactly! I had that feeling too, but let me tell you: with the right preparation, you can almost completely avoid it 😊
Another tip from me: when furniture is very tight in some spots, I placed cardboard or fabric scraps as a "buffer" between the furniture and the wall – this prevented scratches on the furniture.
miAlessio schrieb:
Carrying straps really help with handling, especially if there are only two people.I agree 100%! A carrying strap really changes the handling of bulky items, especially on stairs. Highly recommended!!!
Keep your spirits up, ellina, it will work out great – stay calm and take it step by step!
