ᐅ How do I care for Malm furniture made of particleboard?
Created on: 18 Aug 2022 10:37
gijon
gijon
18 Aug 2022 10:37
I have a somewhat specific question about caring for MDF furniture with a foil finish. I recently purchased a few pieces of this type and naturally want to prevent the surface from becoming dull, getting scratched, or the foil peeling off. When it comes to maintenance, there seem to be several important factors to consider—such as whether special cleaning products should be used or if aggressive substances must be avoided entirely. I’m also interested in how often the furniture should ideally be cleaned and what moisture limits need to be observed during cleaning to avoid damaging the MDF core.
I would appreciate concrete care tips, preferably including recommendations for suitable products, procedures, and what should definitely be avoided. Additionally, any experience with long-term maintenance of furniture like this would be very helpful. Thanks in advance!
gadalu
18 Aug 2022 11:05
Basically, when cleaning Malm furniture made of particleboard with a foil finish, aggressive cleaning agents should be avoided, as they can damage or discolor the foil. Mild cleaning products are recommended, such as a neutral all-purpose cleaner applied with a well-wrung soft cloth. Dust and dry dirt can also be effectively removed using a microfiber cloth, which does not cause scratches.
It is important not to use too much water on the furniture. Although the foil coating protects against moisture, water that penetrates can cause the underlying particleboard to swell, leading to damage. Therefore, it is important to avoid leaving puddles and to dry any damp areas promptly.
For removing grease stains, specific plastic cleaners are suitable but should be used sparingly and only when necessary. Avoid abrasive cleaners or harsh solvents, as they can ruin the material.
As for frequency, regular wiping with a dry or slightly damp cloth is usually sufficient. Excessive intensive cleaning is unnecessary and can cause harm.
Hope this helps with maintenance.
angel
19 Aug 2022 09:22
gadalu schrieb:
Basically, when it comes to Malm furniture made of particleboard with a laminate coating, aggressive cleaning agents should be avoided, as they can damage or discolor the laminate.
I can only confirm that. I have been caring for my Malm furniture this way for years. I also think it’s important not to reach for strong cleaners too quickly, especially when dealing with stains, but to first try water and a mild detergent.
Regarding moisture, I always use a well-wrung cloth, sometimes slightly dampened with diluted vinegar water (but really very diluted). This also helps remove light lime deposits without damaging the laminate.
The furniture should also ideally not be placed in direct sunlight, as UV radiation can fade and make the laminate brittle over time.
In general, wiping the furniture weekly is sufficient, depending on use maybe less often. They don’t attract much dust, but regular cleaning helps maintain their pleasant appearance.
If you ever have a small damage to the laminate, it’s advisable to repair it as soon as possible with special repair kits for veneer or laminate furniture to prevent further peeling.
I hope these practical tips are helpful.
NOAHSAU
19 Aug 2022 13:48
angel schrieb:
I have been maintaining my Malm furniture exactly this way for years.
It’s interesting that many people here are so cautious with cleaning products – though I wonder if that might be a bit excessive. The laminate surface is actually quite durable and specifically designed for furniture use. I have occasionally cleaned heavily soiled Malm furniture with mild dish soap and warm water, without any issues.
gadalu schrieb:
Do not use abrasive cleaners or harsh solvents – these will damage the material.
I agree with that. But how often do you really end up needing such products? And if the furniture is that sensitive, how suitable is it as a mass-produced item anyway?
In my opinion, cleaning shouldn’t be overcomplicated; as long as you’re not using corrosive chemicals or steel wool, the surfaces can handle much more than some suggest. Of course, it’s not wrong to be cautious. Tips are useful, but sometimes it’s okay to take a more relaxed approach :-)
