I recently bought some Ikea Hemnes furniture for my home, and since I have pets—specifically two cats and a small dog—I’m concerned about maintaining and protecting this furniture. My question is: How can I best care for my Ikea HEMNES furniture to prevent scratches, dirt from pet hair, damp paws, or occasional spills of water or pet food? What cleaning methods, products, or protective measures would you recommend that are effective yet gentle on the light finish and wood?
I look forward to your advice, as I want to avoid my furniture becoming worn or unattractive quickly, but I also want to avoid using harsh cleaning products that could damage the surface.
Hello EKINLI,
I can really relate because I also have a small group of lively cats at home 😄. My tip: For the HEMNES furniture, I’ve found that gently wiping it regularly with a damp, not wet, cloth works best. Avoid paper towels; microfiber cloths are better since they pick up dust and pet hair very well.
To protect against scratches, I put transparent felt pads on my cats’ claws (yes, surprisingly, they accept it well!). This helps keep the furniture in good condition longer.
You can also place cat toys around the furniture to distract your cats from being too interested in it.
Additionally, avoid chemical cleaners; water-based ones are always safer for the finish. Ikea also offers special furniture care products that I sometimes use—they’re good for the furniture and have a pleasant smell.
All in all: prevention and gentle, regular cleaning are the magic words! 🙂
Hello EKINLI,
to answer your question thoroughly, I would like to give you a detailed overview of how to keep your Ikea HEMNES furniture well-maintained when you have pets:
First, it is important to know that the HEMNES furniture series is mostly made of solid pine wood, which is lacquered or lacquered and white-stained. The surface is relatively durable but sensitive to aggressive substances due to the lacquer finish.
Here are my step-by-step recommendations:
- Dust and pet hair: Use an anti-static microfiber cloth for regular removal. This helps prevent hair and dirt from settling on the surface.
- Stains and moisture: Wipe damp spots immediately with a soft, slightly damp cloth (water only, no additives). Avoid standing water to prevent reactions with the lacquer.
- Cleaning for tougher dirt: Use a very mild soap solution (e.g., a drop of pH-neutral hand soap in warm water). Afterwards, wipe again immediately with clear water to remove any residue.
- Protection against scratches: For cats, it is advisable to provide scratching posts or mats near the furniture. Where possible, direct scratching on furniture surfaces should be avoided.
- Mechanical protection: Felt pads under sharp furniture edges or at frequently touched spots can help minimize small scratches.
- Care products: Avoid waxes or oils, as these can often cause issues on lacquered surfaces. Ikea’s own water-based furniture care supports the shine and surface without damage.
Finally, an important note: regularly check areas that your pets use frequently for any signs of damage. A little maintenance effort can prevent larger repairs later.
Maybe you could add how often your pets go to the furniture or if your cats are already scratching? That would help provide even more targeted advice.
I would like to add a structured guide for caring for Ikea HEMNES furniture when you have pets:
1. Regular cleaning: Dust weekly using a soft, dry microfiber cloth. The fibers remove dust and pet hair without causing scratches.
2. Cleaning stains: As soon as moisture or stains from pet paws or saliva appear, gently clean with a slightly damp cloth and lukewarm water. Do not use chemical cleaners.
3. Scratch protection:
- Attach felt pads or cushioning material to furniture edges.
- Place cat play areas or scratching posts nearby to relieve the furniture.
4. Avoiding water damage: Do not place wet paws or pet bowls directly on the furniture. If this happens, wipe dry immediately.
5. Care products:
- Use only care products suitable for painted surfaces; water-based furniture cleaners are ideal.
6. Long-term protection:
- Consider protective films or thin transparent covers for heavily used furniture areas.
Finally, pay attention to your pets’ behavior. Occasional training can help them avoid certain pieces of furniture.
I hope this guide is helpful to you.
5. Care products:
Hello EKINLI,
I support the previous answers and would like to add that it can also be useful to regularly check the furniture surfaces for moisture, especially if your dog or cats sometimes nibble or lick the furniture. Such moisture can damage the wood over time.
Additionally, as a preventive measure, I recommend cleaning their paws after walks or playtime (e.g., with a damp cloth) to keep dirt and potential moisture away from the furniture.
When caring for your furniture, try to pay attention not only to the surface but also to the gaps and corners, as dirt and hair tend to accumulate there.
One more tip: furniture that you want to protect particularly well can be treated more often with special furniture wax or a suitable furniture oil for lacquered surfaces. However, always test these products on an inconspicuous spot first.
I hope these tips help you keep your HEMNES furniture looking good for a long time.
