Last year, I bought some furniture from the Ikea Hemnes series, including dressers, nightstands, and a bed made of solid pine wood with a white lacquered finish. Now that it’s time for spring cleaning, I want to not only clean the furniture superficially but also properly maintain it so it stays looking good for a long time.
My question is: How do I best care for Ikea Hemnes furniture in spring? Is simple cleaning enough, or do I need special care products for the lacquered and natural parts? I want to avoid damaging the surface or causing discoloration over time.
Are there specific steps to follow, such as dusting first, then wiping with a damp cloth, and maybe applying care oil or wax afterward? I’m looking forward to detailed tips and experiences from the community. Thanks!
nikeo schrieb:
How do I best maintain Ikea Hemnes furniture in spring?I would say: First, remove the dust, then wipe with a damp, only slightly moistened cloth – not wet. This is enough for the painted surface. For untreated wooden parts, you can occasionally treat them with wood oil, but use it sparingly. Do not use aggressive cleaners.
nikeo schrieb:
How can I best care for Ikea Hemnes furniture in spring?I find it interesting how many people assume Ikea furniture is somehow low quality and doesn’t require special care. Hemnes, in particular, is sturdy and made of solid wood, which is why it deserves more attention.
Not every care guide is practical—some recommend oils or polishes that simply don’t suit Ikea’s finish. In my opinion, the main focus should be on protecting the furniture from excessive moisture and direct sunlight. For spring cleaning, dusting and damp wiping are fine, but using too many care products can clog the pores and change the appearance.
Let’s avoid falling into typical overcare routines and treat the furniture as it is: robust and relatively easy to maintain.
GALEO4 schrieb:
In my opinion, furniture should primarily be protected from excessive moisture and direct sunlight.I agree with that. In spring, I always make sure to care for the furniture gently because I often react sensitively to chemicals.
This is my routine:
- First, dust off with a microfiber cloth.
- Then wipe with a slightly damp cloth, ensuring no excess moisture remains.
- For oiled surfaces, I use a special natural wood care product, but very sparingly.
- I let the furniture dry thoroughly after cleaning and avoid placing it in direct sunlight.
It’s really important to pay attention to the type of surface: lacquered or oiled, as they require different care.
How do you handle this if you have children or pets? Care can be a completely different challenge in those cases.
