ᐅ How do I care for IKEA BESTA surfaces using natural methods?
Created on: 11 Aug 2023 18:07
AmidpraHello everyone, I am currently in the process of caring for my IKEA BESTÅ furniture using natural methods and would like to know the best way to clean the surfaces with household remedies while protecting the materials.
Specifically, I am interested in tips and procedures for:
- removing stains without using harsh chemicals,
- which household remedies are suitable for different surface types (e.g., glass, foil coating, wood look),
- how to achieve streak-free results,
- and how to protect and maintain the surface in the long term without causing damage.
I understand that the surfaces are not all the same – there are foil and glass elements – so I want to be cautious. Who has experience with natural cleaning agents specifically for BESTÅ furniture and can provide detailed advice? Thanks in advance!
Hello Amidpra,
I have read your question carefully and find your concern very well thought out. The BESTÅ series from IKEA is indeed constructed differently – the surfaces mostly consist of melamine-coated particleboard, laminate, or glass. These materials can be sensitive to improper care.
My recommendation for natural maintenance starts with a gentle cleaning solution you can make yourself:
- Mix lukewarm water with a little white vinegar (about 1 part vinegar to 10 parts water). Vinegar is a mild degreaser and has antibacterial properties.
- Use a soft microfiber cloth that does not cause scratches.
Important: Always test the solution on an inconspicuous area first!
For stain removal, depending on the type of dirt, you can mix baking soda with water to form a paste and apply it gently, but be careful as it can be slightly abrasive. For glass surfaces, simply mix water with a splash of rubbing alcohol or lemon juice to achieve a streak-free clean.
To protect laminate surfaces, I recommend using a dry cloth after cleaning to prevent water spots and keep the surface smooth. Avoid oily or wax-based products, as these can damage the laminate.
One more note: Avoid abrasive sponges, harsh cleaners, and excessive moisture, as the edges of the boards can quickly be damaged.
One question: How severe are the stains? Are they more dust or grease? Then I might be able to offer more specific advice.
Hello everyone! I think it’s great that Amidpra wants to clean using natural products! 😊 Natural ingredients can really make a difference, you just need to know how to use them.
Here’s a little tip from my experience: besides vinegar water, I like to use a few drops of olive oil on a soft cloth to polish surfaces a bit, especially those with wood finishes. It gives a nice shine and also provides some light protection against dust!
Also, I used to often clean with lemon juice mixed with water – it not only smells pleasant but also removes light grease very well.
And don’t worry if something doesn’t come off immediately – persistence and gentle cleaning are the key!
Amidpra, have you already tried a product you liked or one you’re unsure about? The community is happy to help!
Hello Amidpra,
I would like to add a structured care guide to your question, based on natural products and specifically suitable for the surfaces of IKEA BESTÅ furniture:
1. Preparation:
- Remove dust and loose dirt with a dry microfiber cloth.
- For glass surfaces, a slightly damp cloth is usually sufficient.
2. Cleaning:
- For melamine-coated surfaces and laminates: mix vinegar essence (1 part) with water (10 parts) in a spray bottle.
- Spray the cloth, not the surface directly, to avoid moisture damage.
- Gently wipe the surface.
3. Stain treatment:
- For stubborn stains, use a paste made from baking soda and water (approximately 1:1 ratio).
- Apply the paste locally with a soft sponge or cloth, let it sit briefly, then gently wipe off.
4. Drying:
- Wipe completely dry immediately after cleaning.
5. Long-term protection:
- For laminates, occasional polishing with a few drops of olive oil or a natural furniture wax is suitable, but use sparingly.
- For glass surfaces, repeat cleaning with a citrus water solution.
Common mistakes I often see are spraying cleaning products directly on the surface and using abrasive cleaners – these cause scratches more quickly and can create dull spots.
If you have any questions about application or problems with specific stains, feel free to ask! I can then recommend appropriate home remedies and application techniques.
1. Preparation:
2. Cleaning:
3. Stain treatment:
4. Drying:
