ᐅ How can I build Ikea Metod kitchen units with plenty of storage and limited space?
Created on: 9 Apr 2023 18:37
Teloson
Teloson
9 Apr 2023 18:37
Hello everyone, I am currently facing the challenge of planning and installing an Ikea Metod kitchen unit in a relatively small kitchen, aiming to maximize storage space without unnecessarily using up the available area. Specifically, I am interested in how to cleverly combine modules to make the most of every centimeter (inch), which cabinet heights and interior fittings are suitable, and if there are any tips for creating a functional and well-organized kitchen unit despite limited width.
What are your experiences with Metod systems in tight spaces, and are there particular tricks with doors, drawers, or corner solutions that are especially space-saving or maximize storage capacity? I would really appreciate your detailed advice, ideally including tips on potential pitfalls during installation. Thanks in advance!
lubla
9 Apr 2023 19:12
Hi, for small kitchens I definitely recommend tall cabinets, ideally reaching up to the ceiling. Use drawers with full extension and internal pull-outs to make the most of storage access. Corner carousels or Le Mans pull-outs make efficient use of corner spaces. Also, consider flat fronts that don’t require space for handles.
bapar
10 Apr 2023 08:03
Hello Teloson, to answer your question with a well-founded assessment, you should first know the exact dimensions of the kitchen: width, height, depth of the niches, as well as the conditions such as water connections or electrical outlets. The Metod system offers several options to maximize storage in small kitchens. I recommend using tall wall cabinets or so-called tall units that reach up to the ceiling, as this effectively utilizes the otherwise wasted upper space. Ikea’s cabinet heights are usually 60 cm (24 inches), 80 cm (31.5 inches), 100 cm (39.5 inches), or 120 cm (47 inches). Cabinets 80 cm (31.5 inches) and taller save space by requiring fewer horizontal cabinets for the same volume. Important for construction are drawers with full extension, as these use the full depth, often equipped with internal organizer systems. Corner solutions like carousels or pull-outs with rotating mechanisms are advisable to make useful use of dead corners, but be sure to pay attention to the quality of the hinges and the distance to the corner; otherwise, the system may jam or tilt when opening. A common mistake in tight spaces is planning too many small cabinets with narrow doors, which costs valuable storage space in favor of higher flexibility but is mostly counterproductive. It is better to have fewer, but tall and deep base cabinets with good pull-outs. Interior fittings such as adjustable inserts or dividers further organize the storage space and help maintain an overview, saving time later on. One more tip for construction: pay attention to the load capacity of the shelves when storing heavy appliances or provisions, sometimes additional reinforcement is needed. I would be interested to know the exact dimensions of your kitchen to plan more specifically.
Teloson
10 Apr 2023 09:45
bapar schrieb:
I’m interested in the exact dimensions of your kitchen to plan more precisely.
Thank you for the detailed post! The kitchen unit is about 240 cm (95 inches) wide, 60 cm (24 inches) deep, and the ceiling height is 250 cm (98 inches). Water connections are centrally positioned in the middle, so I plan to place the sink and dishwasher in the center of the unit. The room is very narrow and elongated, so I want to minimize how far the units protrude into the room. I found your tips on corner solutions interesting, but currently I’m not using any corners because the unit needs to run straight along one wall. Could you share some advice on the optimal combination of drawers and pull-out cabinets, especially for the 60 cm (24 inches) width? How can storage space be organized best in that width?
toril
11 Apr 2023 07:56
bapar schrieb:
First, I recommend using tall wall cabinets or so-called pantry cabinets,
That is basically correct. For your 240 cm (95 inches) wide Metod kitchen run with 60 cm (24 inches) depth and no corner solution, I suggest dividing it into several modules with drawers and pull-outs in 60 cm (24 inches) widths, depending on content and usage:
- For the area under the sink, integrate a cabinet with pull-outs for optimal access to cleaning supplies. Interior pull-outs with multiple levels are often suitable.
- Next to the sink, deep drawers with full extension are recommended, ideal for cutlery, cooking utensils, and smaller kitchen tools.
- For heavy items like pots, wide pull-outs with robust slides are practical.
Use adjustable internal dividers and boxes wherever possible to make flexible use of the space. Tall wall cabinets can also be built with lift-up doors if headroom is limited.
In conclusion, it is advisable to precisely plan the kitchen run using the IKEA kitchen planning tool. There you can virtually combine individual modules and adapt them to the room situation.
Using pull-outs makes sense with 60 cm (24 inches) depth overall, as the full storage space is usable when pull-outs are not built on standard fronts but contribute to organization with internal fittings.
