ᐅ How can I build IKEA Metod kitchen units in a functional and space-saving way?
Created on: 15 May 2015 08:37
Andreakla
Andreakla
15 May 2015 08:37
I am currently planning the layout of my new kitchen using IKEA Metod kitchen units and want to design it to be as functional and space-saving as possible. Since the room size is limited, I am mainly looking for advice on how to best plan the Metod cabinets to maximize storage space without making the kitchen feel cluttered or confusing.
I am particularly interested in:
- Which cabinet combinations have proven effective for making the most of small or narrow spaces?
- Are there specific cabinet types or interior fittings within the Metod range that are especially recommended for space-efficient storage?
- What is the best approach for planning the countertop length and the positioning of the stove, sink, and refrigerator to ensure functional workflows (work triangle, etc.)?
I have done some research but have found varying opinions and would therefore like to benefit from the experiences shared here in the forum. How do you set up your Metod kitchen units to make them functional and space-saving? Are there any tips or recommendations that could help IKEA newcomers avoid planning mistakes?
Thank you very much in advance for your support!
rotofra
15 May 2015 10:21
Hello Andreakla,
your topic is very important because the Metod series offers many options, but its flexibility can quickly become overwhelming.
A few of my tips for setting up Metod kitchen units in a space-saving and functional way:
- Planning: Start with precise room measurements, including windows, doors, and utility connections. Use the IKEA planner software and check whether the suggested dimensions match your space.
- Cabinet system: Place tall cabinets at the ends to use storage space from floor to ceiling, for example, a pantry cabinet with pull-outs to make deep items easily accessible.
- Drawers: Choose drawers instead of doors whenever possible, as they significantly improve access to contents. Pull-outs and organizers help with visibility inside.
- Cabinet widths: Metod offers carcasses in 40, 60, and 80 cm (16, 24, and 31 inches) widths. In small rooms, prefer more narrow cabinets rather than fewer wide ones to keep storage divided and more organized.
- Work surfaces: Plan enough countertop space between the stove and sink (at least 60 cm (24 inches)) to maintain a good workflow within the kitchen work triangle.
- Corner solutions: Use swing-out or carousel elements to avoid loss of space in corners. Angled units increase usable area.
- Wall cabinets: Keep wall cabinets not too deep (maximum 35 cm (14 inches)) to create more headroom and ease of movement.
I would also like to know:
- What is the exact size of your kitchen, and where are the utility connections located?
- Which appliances are you planning to install?
This way, I can provide you with more specific advice.
JONUFA
15 May 2015 11:02
Metod is very flexible. Use many drawers, as they are well-organized. Corner cabinets with carousels are excellent, saving space. Make full use of tall cabinets for storage all the way up to the ceiling. Choose narrow cabinets to distribute storage space more efficiently.
V
valerie-tr
16 May 2015 09:44
Hello Andreakla,
I’d like to add some more detailed insights on the planning and optimization of Metod kitchen units, complementing rotofras’s explanation. A systematic approach is especially important if you want to design the layout to be both functional and space-saving.
First, you should clearly define the room shape and current usage requirements: What workflows do you have? Cooking, baking, washing, tidying up? It’s important to pay close attention to work paths since unnecessary movements waste energy and time.
Regarding the cabinets: Metod offers various carcass sizes (20, 40, 60, 80 cm). I recommend focusing on 40- and 60-cm (8-inch and 24-inch) modules where possible. 20-cm (8-inch) units are ideal as supplements for narrow gaps. For overhead storage, tall cabinets with internal pull-outs or pull-out pantry units are very useful to store heavy items ergonomically.
Key tips for space-efficient storage management:
- Drawers with inserts: Organize cutlery, pots, and kitchen tools effectively.
- Inner drawers for flat items that often end up neglected.
- Corner cabinets with LeMans or Magic Corner mechanisms to avoid wasted corner space.
- Wall cabinets combined with open shelving for frequently used items.
For the work surface, ensure at least 60 cm (24 inches) between functional zones (sink, stove, refrigerator), ideally more, to make food preparation more comfortable.
Also, consider lighting: Good under-cabinet lighting improves the work area.
One more question: Are you planning a gas or electric cooktop? This also affects the installation location and outlet planning.
If you like, I can send you a checklist for kitchen planning to help you keep track of all module selections.
JEREMIAH38
16 May 2015 12:29
Hi Andreakla,
I completely understand how challenging it is to plan a Metod kitchen. I felt the same way when I first wanted to renovate. The many configuration options almost overwhelmed me.
What really helped me was not only using the IKEA planning tool but also thinking about how I actually want to use the kitchen. For example: Where do I prefer to cook? How many items do I really need every day? Which things usually just stay in the cabinets?
When I read your post,
rotofra schrieb:
Work surfaces: Plan for enough work surface between the stove and the sink (at least 60 cm (24 inches)) to maintain good workflow within the kitchen work triangle.
I find this point essential. The work triangle is truly the key to a functional kitchen. Even if space is tight, I always remind myself that a good working height, enough counter space, and storage are more important than visual perfection.
If you’re stressed about choosing or the order of things, don’t worry. I made many mistakes at first, but I kept trying. It will definitely get easier for you over time!
Rashadmeo
17 May 2015 07:15
Hey Andreakla and everyone else!!
I love the Metod series because it’s so versatile. Thinking back to my first kitchen project, it was quite a challenge, but with the right motivation, everything worked out great!
My tip: make full use of all available heights. For example, I installed shelves at the top that work perfectly with small boxes. This way, every centimeter (inch) is used really smartly!
Also very important: instead of large cabinet doors, opt for lots of drawers so nothing gets lost and everything is easy to reach.
Don’t stress, it will grow with you! It’s best to take it step by step: plan, build up, see what works, and adjust – it’s fun that way!
Hope I could send some energy and encouragement your way 🙂
