ᐅ How can I build IKEA Metod kitchen islands with plenty of storage space myself?
Created on: 18 Jul 2024 09:17
Miixpu
Miixpu
18 Jul 2024 09:17
I am planning to build an IKEA Metod kitchen island myself and want to include as much storage space as possible. My idea is to combine the standard cabinets in a way that allows for many drawers and compartments without making the island look too bulky. Specifically, I am wondering about the best approach regarding planning, selecting the modules, and ensuring stability. Are there any proven methods or tips on how to make the most of the Metod components to maximize storage?
I am also interested in how to securely fasten the countertop and whether there are any special recommendations for the plinths (kickboards) or interior fittings. I would appreciate your experiences and advice, especially if anyone has already built a similar kitchen island and can share the challenges encountered.
Thanks in advance!
Dustin
18 Jul 2024 09:42
for plenty of storage space, you should combine base cabinets with drawers, as they are deeper and more practical than doors. Install the countertop using suitable brackets, making sure that the toe kick height remains consistent. Stability is achieved through precise installation according to the instructions.
RENMA
18 Jul 2024 11:03
To optimally design an IKEA Metod kitchen island with ample storage, it is advisable to first precisely measure the room and clearly define the functional requirements. The choice of cabinet types should be based on their intended use: drawers provide better access and organization, while pull-outs and inner pull-outs create flexible storage space.
For countertops, it is recommended to secure them using the supplied brackets specifically designed for Metod. For islands without a back panel, additional attention should be given to securely anchoring them to the ceiling or floor to ensure stability.
Additionally, the kickboard height should be considered, as different heights can affect both the appearance and functionality (e.g., legroom). Recommendation: use consistent designs for the plinth profiles.
Finally, careful planning of electrical connections is important if appliances or lighting are to be integrated.
TEOZAR
18 Jul 2024 12:47
Hello Miixpu,
I can understand that storage space in a kitchen island is a main concern. Basically, I recommend starting with a clear layout:
- Think about which items you want to store in the island (pots, cutlery, pantry items, etc.).
- Then choose base cabinets with the maximum drawer heights and appropriate fittings.
It is important not to stack the modules too high, as the standard height is usually 60 cm (24 inches) plus the countertop. For more storage, you can also include some tall cabinets.
Regarding stability: If you combine several modules, you should definitely connect them using the joining fittings provided, to create a solid unit. When attaching the countertop, make sure it is securely supported on all sides. If you use a thicker countertop, you should also consider the weight when checking stability.
If you want to make the island mobile, there are special casters available, but this often reduces stability. You can also add extra internal braces if you plan to store heavy items.
I hope this helps you!
Miixpu
19 Jul 2024 08:31
This brings me to a follow-up question: Is there a way to customize the height of the island, for example making it higher or lower, without compromising stability? In particular, I wonder if it is possible to adjust the legs or use different modules as a base to achieve a comfortable working height.
I am also interested in how to create storage space for tall pots or pans, which often don’t fit in standard drawers. Are there modular solutions within the IKEA Metod system that are suitable for this?
Thanks in advance!
fredle
19 Jul 2024 11:22
Hello Miixpu,
Regarding your question about the height: IKEA Metod offers adjustable legs with a standard height of about 10 cm (4 inches). For a taller island, you can consider the following options:
- Purchase taller adjustable legs or use alternative furniture feet.
- Build additional base frames from wood or metal to raise the foundation.
It is essential to regularly check the stability, especially if the island is freestanding. Keep in mind that a very tall island can be less ergonomic.
For storage of tall pans, I recommend tall cabinets or base cabinets with large compartments and pull-out interior drawers. IKEA also offers inserts and organizers that can be used with large drawers to optimize storage space.
If you want to combine drawers of uneven heights, it’s best to use drawers with different heights, placing tall items in the deeper drawers and smaller items in the shallower ones. This works very well with Metod, as the drawer heights vary.
Summary:
- For height variation: adjustable or custom legs/bases
- For tall utensils: large drawers, tall cabinets, pull-out interiors
When building, pay attention to module compatibility and uniform joints to ensure a visually harmonious result.
