ᐅ How do I build IKEA Metod kitchen islands with an integrated seating area?
Created on: 27 Sep 2024 08:14
refoglaHello everyone, I am planning to build an Ikea Metod kitchen island with an integrated seating area and am looking for a detailed guide or tips on the best way to approach this.
Specifically, I am interested in:
- How can I combine the standard Metod base cabinets to create a stable, freestanding island?
- Which countertops work best for the overhang needed for the seating space?
- Are there any special installation instructions when integrating a seating row with bar stools?
- How can I secure the island to the floor without damaging the kitchen?
I already have experience with kitchen assembly, but the kitchen island is new territory for me. I look forward to your practical experience, advice on necessary additions (e.g., kickboards, brackets, extra feet), and any potential pitfalls I should avoid.
For a stable island, it’s best to use the 60cm (24 inch) Metod base cabinets and connect them with sturdy brackets from the inside.
Choose countertops with a thickness of at least 3-4cm (1¼-1½ inches), such as solid wood or laminate. Plan for an overhang of about 30cm (12 inches) for the seating area.
Secure the island with floor anchors that don’t require drilling into the floor, but use rubber feet instead.
Hello refogla, your project sounds exciting!
Regarding the installation of the Metod modules as an island, I can recommend the following:
- Connect the cabinets using the supplied corner brackets for stability, and add extra metal brackets if needed for additional support.
- For the countertop, it is advisable to choose a slab at least 4 cm (1.5 inches) thick, which you can have cut to create an overhanging seating area of 25 to 35 cm (10 to 14 inches).
- Make sure the countertop is supported on the seating side by sturdy brackets or a proper substructure.
- Secure the island using adjustable-height glides to compensate for uneven floors, and if possible, use clamping or screw fasteners on the floor without invasive measures on tile or wooden flooring.
If you plan to equip the island with electrical installations, include cable outlets in the countertop.
For Metod in general, the toe kick is important for a clean finish. For the seating area, you can omit the toe kick or install a deeper plinth panel to achieve the correct table height.
I would like to add a note on load distribution for seating areas: The overhang of the countertop should be supported to prevent deformation. Metal brackets or wooden braces are often installed underneath the countertop for this purpose.
It is also important to consider the height of the bar stools so that the seat height and overhang align well.
A common mistake is to support the island only on the supplied legs without any additional stabilization. Especially when sitting, so much pressure is applied that everything loosens quickly.
Great topic! Building your own kitchen island with a seating area using Ikea Metod cabinets is definitely doable and really fun!
Tip: Be sure to use the Ikea planner tool, it’s very helpful for the measurements! For the seating height, I chose a stool height of 65–70cm (26–28 inches), which works perfectly with the overhang of the countertop.
Important: Make sure to screw everything tightly and don’t skimp on the brackets, otherwise the whole structure will wobble.
No worries, it’s not rocket science—just take it step by step. Good luck, and feel free to share your progress here!
Paunon schrieb:
Choose countertops with a thickness of at least 3–4 cm (1¼–1½ inches), for example, solid wood or laminate.Is that really always the best choice?
Laminate might be sturdy, but it often looks cheap and can delaminate under heavy use. Solid wood is more expensive and requires more maintenance, but it also has a higher risk of warping due to swelling and shrinking.
I think the option to choose quartz composite or durable engineered materials for countertops is often underestimated. These are stable, scratch-resistant, look high-end, and maintain their appearance well over time. Does anyone have experience, especially with Metod and such materials?
