ᐅ How can I build IKEA Metod kitchen islands with plenty of storage space?
Created on: 24 Aug 2022 09:37
Kuwerner
Kuwerner
24 Aug 2022 09:37
Hello community,
I am currently planning to build a kitchen island with plenty of storage and want to use the Ikea Metod system for this. I am particularly interested in how to approach building a Metod kitchen island to make the best use of the available space while ensuring a stable structure. The following points are especially important to me:
- Tips for selecting the right base cabinets (width and depth)
- Options for integrating drawers and pull-outs to optimize storage
- Suggestions for a practical layout (for example, storage for pots, pantry items, or dishes)
- Advice on the necessary support framework and countertop that can withstand heavier loads
Do you have experience or even guides on how to carry out this project? Are there common mistakes to avoid? I look forward to practical advice and tips, even if they are based on systems other than Ikea Metod.
Thanks in advance!
Ethan
24 Aug 2022 12:21
Hello Kuwerner,
your question is very well thought out and shows that you are already planning quite concretely! When building an Ikea Metod kitchen island with plenty of storage space, there are some important points to consider.
First, regarding the choice of base cabinets: The Metod series offers various depths (37 cm (15 inches), 60 cm (24 inches), 80 cm (31 inches)) and widths (20 to 120 cm (8 to 47 inches)). For an island, it is usually recommended to choose the 60 cm (24 inches) deep cabinets, as they provide enough storage space and work well with the countertop. If you need particularly large storage capacity, you can place several base cabinets side by side or choose the deeper 80 cm (31 inches) units, provided the room size allows it.
For drawers, I recommend opting for tall drawers. These are great for pots, pans, or tall storage containers. Drawers with multiple levels also help keep things well organized. Also think about the internal organization – inserts for cutlery, spices, or plates help maintain clarity.
Regarding stability: The Metod units are sturdy but should be securely connected in an island setup. Use Ikea’s connector fittings to fix the modules together. A load-bearing countertop (for example, made of solid wood or a high-quality composite board) provides stability from above. If the island is freestanding, a reinforced base or frames for additional stability are advisable, especially if the drawers are frequently used.
Common mistakes include:
- Insufficient depth limiting storage space
- Missing fixation of units, which leads to instability
- Incorrect countertop choice, causing warping
I hope this helps you make good progress!
Palenar
25 Aug 2022 07:46
Hello Kuwerner,
I would like to address your points here with some detailed information and also share typical challenges I have encountered when building Metod islands.
- Cabinet dimensions: As Ethan already mentioned, a depth of 60 cm (24 inches) is a good starting point. However, it is also possible to install cabinets from the back (for example, 37 cm deep (14.5 inches)) to optimize room depth or to conceal technical installations underneath.
- Modular connection: It is important to use the metal connectors provided by Ikea or alternatively sturdy angle brackets when connecting the individual modules. Even with heavy drawers, this ensures consistent stability and prevents tilting.
- Drawers: Tall drawers with full extension make optimal use of storage space, as you can reach everything at the back. I also like to use inner drawers, that is, two-tier drawers, to store smaller items separately.
- Worktop and supports: If you are planning a larger island, the worktop alone may sag. I recommend either a thick solid wood worktop (at least 4 cm (1.6 inches) thick) or integrating a supporting frame made of metal or wood underneath the worktop. If your island has a seating surface or an overhang, stable supports should definitely be installed in those areas.
- Planning the layout: Think carefully before purchasing about what you want to store in the island. Heavy items should be stored as low as possible, and frequently used dishes or appliances in easily accessible drawers.
One thing that is often underestimated is integrating electrical connections wherever necessary – for example, for induction cooktops or power outlets in the island.
Finally, a question for you: How large is the room, and do you already have a rough planning sketch? This would make it much easier to give targeted advice.
Kuwerner
25 Aug 2022 14:04
Palenar schrieb:
One final question for you: How large is the room, and do you already have a rough planning sketch? That way, it’s much easier to give targeted advice.
Thanks Palenar for the detailed information!
The available space for the island is approximately 2.5 x 1.2 meters (8 ft 2 in x 3 ft 11 in), rectangular. The island should be positioned as centrally as possible in the room and primarily provide storage for cooking utensils, pots, and storage containers.
Currently, I only have a rough sketch on paper, no CAD drawing. The main goal is a combination of at least two 80 cm (31½ in) wide base cabinets with drawers, plus as many additional drawers as possible alongside. I also want a worktop about 90 cm (35½ in) deep, with a 15 cm (6 in) overhang on one side to create a small seating area.
Are there any important considerations regarding the dimensions? For example, stability issues with overhangs or specific solutions for mounting the worktop across multiple base units?
SONLIS
26 Aug 2022 11:33
Kuwerner schrieb:
Are there important points I should pay attention to regarding the dimensions? For example, stability aspects with overhangs or special solutions for attaching the countertop to multiple base units?
Good morning,
Regarding your specific situation and dimensions, I can say the following:
- For an overhang of 15 cm (6 inches) on one side, you should definitely consider reinforcements. A cantilever of more than 10 cm (4 inches) without support can lead to bending or sagging of the countertop over time, especially if it is made of lighter materials like particleboard or MDF with laminate.
- Ideally, install a support strip underneath the overhang—this could be wooden battens or metal profiles—secured at the ends of the base cabinets or to additional legs. This will prevent wobbling and deformation.
- When attaching the countertop to METOD base cabinets, I recommend using the specific mounting kits provided by Ikea, which not only secure the countertop but also allow for slight movement since wood-based panels can expand or contract slightly due to changes in humidity.
- If storage is important, use tall drawers where possible and combine them with inner drawers or organizers for items like cutlery or small utensils. Shorter but wider drawers located behind doors can also create extra storage space.
- To maximize storage further, consider side units or pull-out pantry drawers that fit into narrow cabinets.
In summary: prioritize stability with reinforced supports first, then plan carefully how many and which type of drawers to install.
Good luck with your build!
