ᐅ How can I space-efficiently install IKEA Metod cabinets with sliding doors?
Created on: 25 Jul 2023 14:07
dranu
Hello everyone, I am planning to install IKEA Metod kitchen cabinets with sliding doors in my kitchen in the most space-saving way possible. My specific question is: How can I build the cabinets with sliding doors to maximize space gain without compromising the stability or functionality of the sliding doors? Are there particular assembly steps or tips to consider for optimal use of the installation space, especially when space is limited in height and width? I have read that sliding doors sometimes need to be mounted differently than regular doors, and I want to approach this as systematically as possible. I would appreciate detailed experiences and advice, including on choosing the right sliding door variants for Metod. Thanks in advance!
BOMILAN
26 Jul 2023 14:08
Sliding doors require sturdy tracks at the top and bottom.
With Metod, this is usually standard.
First, install the cabinets, then the tracks.
Leave the door width slightly smaller than the cabinet opening to allow for clearance.
Make sure the installation is level; otherwise, the door may jam.
JAFUHAU
27 Jul 2023 09:31
I think sliding doors are great for small kitchens, but it can be frustrating when the doors stick or don’t slide smoothly.
It is important to measure accurately at the beginning and then carefully follow the instructions step by step.
If you have any doubts, it’s better to install the doors in stages and test them in between.
This way, you can avoid unnecessary stress.
klo40
27 Jul 2023 10:02
JAFUHAU schrieb:
It is important to measure very accurately at the beginning and then carefully follow the instructions step by step.
Exactly, that is the best advice. In addition, I would like to add that before final assembly, you should definitely test the sliding rails without the doors. This way, you can ensure they are perfectly parallel and level, and free of any deformations.
If you have a corner space, also check whether the doors could be damaged by sliding against the walls. Protective strips can be a possible solution here.
