ᐅ How do I build IKEA Metod cabinets with sliding doors for small spaces?
Created on: 8 Sep 2021 09:22
willmarf47W
willmarf478 Sep 2021 09:22Hello everyone,
I am planning to install IKEA Metod kitchen cabinets with sliding doors in my small apartment, as space is very limited and regular hinged doors would not be practical due to the lack of room. My main questions are: What is the best approach for installing Metod cabinets with sliding doors, which specific components or modifications are required, and what should I especially consider in small spaces to ensure the sliding doors work smoothly while maintaining enough storage capacity?
I already have some basic experience with assembling furniture but no prior experience with sliding door systems in this series. Any advice on suitable options, fitting tolerances, and potential pitfalls would be greatly appreciated.
Best regards!
Best regards!
Hello willmarf47,
I’m happy to provide you with a structured guide on how to optimally install IKEA Metod cabinets with sliding doors for small spaces.
- First, you should select the appropriate cabinet types that work well with sliding doors. In the Metod series, tall cabinets without hinged doors are especially suitable.
- There are specific sliding door tracks from the “Pax” system that are often compatible with Metod as well. Make sure the tracks match the height of your cabinets.
- The installation starts with assembling the cabinet carcass, which must be perfectly level and flush; this is essential to prevent the sliding doors from sticking later.
- The sliding door hardware is installed at the top and bottom of the carcasses, usually with small rollers at the bottom and guide rails at the top.
- Especially in small spaces, measure carefully and choose a suitable track that ensures smooth sliding and long-lasting reliability, even with frequent use.
- Before final installation of the doors, check that the track runs freely and adjust if necessary. Even small unevenness in the floor or walls can cause issues otherwise.
Summary: Plan the room measurements precisely, select appropriate tracks, build the cabinet accurately, and install the sliding door systems with care.
If you like, I can also provide tips on common mistakes and how to avoid them. Good luck!
For small rooms, I recommend choosing narrow cabinets and fitting the sliding doors with smooth-running rollers.
Make sure the tracks are installed cleanly and straight; otherwise, the doors may get stuck.
Watch out for floor clearance: If the floor is uneven, it can cause problems.
Hello willmarf47,
I’d like to address your concerns in detail, as installing IKEA Metod cabinets with sliding doors in small spaces can be particularly challenging:
First, the choice of doors: IKEA offers only a few sliding door systems specifically for Metod; often, compatible PAX sliding doors are used instead. These systems differ technically from standard hinged doors—they operate with top and bottom tracks in which rollers run. It is important that you have the exact measurements of your cabinet carcass, as the sliding doors need to fit precisely to prevent sticking or excessive play.
Second, pay close attention to installation accuracy. Small spaces often allow little tolerance. Measure the space multiple times, not just once—floors can be slightly uneven and walls might not be perfectly vertical. Use a spirit level and, if possible, shims to align the cabinet perfectly.
Third, when fitting the sliding doors, carefully insert the rollers into the tracks and ensure the door is not misaligned. The fittings can be somewhat delicate. Avoid overtightening screws, as this can cause the mechanism to jam.
Fourth, the sliding mechanism requires maintenance: in tight, enclosed spaces, dust can accumulate and make the doors harder to operate over time. A light lubrication film on the tracks (for example, silicone spray) helps maintain smooth functionality.
Finally, I recommend practicing installing the sliding doors on a sample piece or a freestanding cabinet before the final installation to get a feel for the mechanism.
If you have any specific questions about modules or installation situations, feel free to ask.
