ᐅ How can I build Ikea Metod cabinets with sliding doors for maximum space utilization?
Created on: 6 Sep 2020 10:13
Elias62
Elias62
6 Sep 2020 10:13
Hello everyone, I am planning a new kitchen and pantry project in my house and want to use Ikea Metod cabinets with sliding doors to make the best and most efficient use of the available space. My question is: how can I install Ikea Metod cabinets with sliding doors in a practical and space-saving way, without losing the flexibility of the shelving and easy access? I am especially interested in how to properly integrate the sliding door mechanism and design the interior in a way that neither wastes space nor limits usability due to the sliding doors. Are there any proven tips or common pitfalls to watch out for when combining Metod cabinets with sliding doors? Thanks in advance for all helpful advice!
Danial
6 Sep 2020 11:45
Elias62 schrieb:
My question is: How can I install Ikea Metod cabinets with sliding doors in a practical and space-saving way, without sacrificing the flexibility of the compartments and easy access?
This is a very good yet complex question because Ikea Metod does not actually offer standard sliding doors that are directly compatible. You either need to add complete systems from third-party suppliers or modify the doors yourself accordingly.
I would suggest first planning the maximum fixed depth and width of the units, as sliding door systems often require a bit more space in front or on the side for the tracks. It is important that the tracks are installed precisely, otherwise the door will be difficult to slide.
For flexibility inside, I recommend choosing narrow pull-outs and shelves with sturdy guide systems. A combination of drawers and compartments is also a good idea to optimize access.
tarju41
6 Sep 2020 11:49
I would choose cabinets deep enough so that the sliding doors are not too close to the front. Also, get and install suitable sliding rails. Use adjustable shelves inside to customize the storage space according to your needs.
lochen
6 Sep 2020 12:30
Elias62 schrieb:
I am particularly interested in how to correctly integrate the sliding door mechanism and design the interior space so that I neither waste space nor limit the usability of the sliding doors.
First, you should always install the sliding door tracks on a solid, level surface. For Metod, aluminum tracks work best since you can securely fasten them exactly at the top and bottom.
Regarding the interior space: avoid very deep shelves, as they can restrict access. For optimal space utilization, drawers and pull-outs are helpful, and these are available in standard Metod depths.
I would also recommend having the doors slide side by side rather than overlapping; this creates a seamless front without offset that could block storage space.
lalutau
6 Sep 2020 15:02
To optimize space utilization, it is important to accurately calculate the exact depth of the Metod cabinets in combination with the sliding door system. A typical depth is 60 cm (24 inches), but the tracks and doors each require several centimeters more, so the effective usable space is slightly smaller.
One tip is to use lightweight materials for the doors to reduce the load on the tracks and make the sliding doors easier to operate. Wooden or MDF panels are often too heavy, especially when they are large.
You should also plan the cabinet width so that the sliding doors are not too narrow, as this makes them difficult to handle. Two doors that slide toward the center are usually the most practical solution.
In general, precise measurement planning is essential to avoid problems later with the mechanics and interior layout.
Tause
7 Sep 2020 08:47
Danial schrieb:
That is a very good and at the same time complex question because Ikea Metod does not actually offer standard sliding doors that are directly compatible.
That is true, and this is exactly where I see a problem. However, when using alternative third-party systems that are not perfectly matched to Metod, there is often extra work required for adjustments and compromises in the front appearance.
The issue of load capacity of the sliding mechanism should not be underestimated either. Especially for kitchen cabinets with a lot of weight, a high-quality track and roller system is essential.
One idea would be not to design the system entirely around sliding doors but to use hinged doors for certain areas and sliding doors for others, in order to minimize effort and potential sources of error.
