ᐅ How can I build IKEA Metod cabinets with plenty of storage space for small kitchens?
Created on: 25 Dec 2018 09:37
DaanmaHello everyone,
I’m currently planning to create more storage space in my small kitchen using Ikea Metod cabinets. Since the kitchen is really limited in size, the question is how to arrange and organize the modules to maximize usable storage space without making the solution feel cluttered or compromising functionality. Tips on the best cabinet sizes, combinations of wall cabinets and base cabinets, as well as practical interior fittings like pull-outs or inserts would be very helpful. Are there also tricks for making the most of dead corners or staying flexible in use? I look forward to your experiences and suggestions, especially what has proven effective in very small layouts.
JOHNATHAN25 Dec 2018 11:43Daanma schrieb:
Since the kitchen is really limited in size, the question is how to arrange and organize the modules to maximize usable storage space without making the solution feel overloaded or compromising usability.Hi Daanma,
I completely understand what you mean—small kitchens can quickly feel cluttered if not planned cleverly.
With Metod, it’s worth working with tall cabinets that reach up to the ceiling. This lets you use the space very efficiently—store items you use less often up high. There are also narrow pull-outs that can be hidden behind doors when space is tight.
A little tip: use internal fittings for flap doors or corner solutions, so you can easily access everything in the corners. And don’t forget, comfort is key—better hardware (soft-close, full extension drawers) makes using the kitchen pleasant even in a small space.
Good luck, and feel free to ask if you need more details!
Daanma schrieb:
Interesting would be tips on the best cabinet sizes, combinations of wall cabinets and base cabinets, as well as sensible interior fittings like pull-outs or inserts.Hello Daanma,
I’d like to try to give you a more structured answer because a well-thought-out concept is especially important in small kitchens.
1. Measure the space: Start with precise measurements of the room and utility connections. Use a planning tool or Ikea’s official app to test different layouts.
2. Cabinet sizes: Ikea Metod offers various heights – 40, 60, 80, 200 cm (16, 24, 31, 79 inches) and more. For small kitchens, 60 cm (24 inches) high base cabinets are standard, with matching tall pantry cabinets up to 200 cm (79 inches) being ideal.
3. Interior fittings: Full-extension pull-outs provide the best access, especially in deep cabinets. Interior pull-outs and organizers help to make good use of the available volume.
4. Corner cabinets: Carousel units or LeMans-style pull-outs work well here. They aren’t inexpensive but greatly increase the usability of corner spaces.
5. Combining wall cabinets and base cabinets helps to stagger the wall area with varying depths, creating a lighter visual effect.
My recommendation: Focus on vertical storage and flexible interior solutions so you can accommodate a variety of items.
Feel free to ask if you have further questions!
lochen schrieb:
Corner cabinets: Carousel or LeMans pull-outs are good options here.I would strongly advise against those if space is really limited. Floor-to-ceiling drawers that you can freely organize with boxes are a better choice. Corner solutions are expensive and often hard to access.
Hello Daanma,
I would like to add one aspect that is often overlooked: the layout and space utilization through smart planning of door swings and handle solutions.
- Choose doors and drawers that are easy to open, even with limited clearance space.
- Push-to-open systems or handle bars offer advantages here.
- Pay attention to the arrangement of cabinets to avoid doors blocking each other.
It is also useful to consider the frequency of use of different areas in the planning. Frequently used items should be easily accessible, while rarely used ones can be stored in upper or lower cabinets.
I also recommend focusing on flexible interior fittings: dividers, inserts, and adjustable-height shelves make organization easier.
If you like, I can provide examples of combinations that work particularly well.
