ᐅ How do I build Ikea Metod cabinets with plenty of storage space for a hobby room or home office?
Created on: 11 Jan 2022 08:47
IVETTESAR
IVETTESAR
11 Jan 2022 08:47
I am currently redesigning my hobby and workroom and have chosen the Ikea Metod cabinet system because it seems flexible and modular. My goal is to create as much storage space as possible to accommodate a wide variety of materials such as craft supplies, books, tools, and binders.
I have already made some considerations but would like to know the best way to plan and assemble Metod cabinets in order to make optimal use of the available space. I am particularly interested in:
- Tips for combining different cabinet sizes and drawers
- Practical interior fittings (e.g., inserts, dividers) for better organization
- Possible ideas for integrating work surfaces or fold-down tables
- How to best account for weight and stability
Who has experience with longer runs or corner solutions and can share practical advice? What is the best way to plan ahead, and what should be definitely considered during assembly to ensure it is not only functional but also durable?
I look forward to your suggestions!
kibutar
11 Jan 2022 12:09
Hello IVETTESAR,
I’m taking the time to provide a comprehensive overview of the Metod system, focusing on maximizing storage space for a hobby or home office. Your request is great because proper storage planning requires careful preparation and a good understanding of the system.
First, regarding planning: You should measure the available space precisely—height, width, depth, and also any obstacles such as radiators or windows. Generally, Ikea Metod units come in various widths (20, 40, 60, 80, and 100 cm (approximately 8, 16, 24, 31, and 39 inches)) and depths (37 and 60 cm (approximately 15 and 24 inches)), with 60 cm (24 inches) depth usually providing sufficient storage for a workspace and allowing extra depth for items like binders or larger tools.
From my experience, I recommend combining different heights (40, 60, 80, 100 cm (approximately 16, 24, 31, 39 inches)) to fully utilize vertical space. Be cautious: stability is especially important for taller units. You should definitely secure the Metod units to the wall, particularly if you plan to store heavy items.
Regarding interior fittings: Ikea offers inserts, drawer organizers, and flexible dividers to keep drawers orderly. Pull-out shelves are also great for easy access to items stored at the back. For hobby areas, smaller boxes inside drawers are useful to prevent small parts from getting mixed up.
Corner solutions work well by combining cabinets with corner modules beyond the Metod system—for example, a matching carousel unit for optimal space use. Work surfaces can be installed on standard Metod base cabinets or on more open units, sometimes with a fold-down table feature. Make sure to mount movable elements securely, and check the manufacturer’s recommended load capacity (usually up to 20-30 kg (44-66 lbs) per surface).
One final important tip: avoid placing Metod units loosely side by side. Use the included connectors and wall brackets to prevent tipping hazards and deformation. Also, ensure an even load distribution to avoid drawer runner wear.
What materials are you mainly planning to store? Depending on weight and volume, I can provide more specific advice on individual systems or alternative add-ons.
Best regards!
IVETTESAR
11 Jan 2022 15:32
kibutar schrieb:
Which materials are you mainly planning to store? Depending on weight and volume, I can provide more specific advice on individual systems or alternative additions.
Thank you for your detailed response!
Regarding the contents: I mainly need to store craft materials (small boxes with beads, fabrics, tools), some books and binders, as well as technical equipment. The binders are naturally the heaviest and require a minimum depth of 37 cm (15 inches). The craft supplies should be organized more clearly in smaller compartments.
I tend to prefer shallow drawers for small items and open shelving with shelves for books and binders. What is the best way to combine drawers of different depths within the same cabinet? Are there any clever solutions?
I would like to have work surfaces integrated into the cabinet row, but practical to use and not too high (about 75 cm (30 inches)), which is somewhat challenging with Metod.
Looking forward to any tips you have.
klo61
12 Jan 2022 10:05
Hello IVETTESAR,
I would also like to share a few thoughts with you. Your idea to combine different drawers for small items with open shelves for folders and books is very practical. Metod is quite flexible for exactly that purpose.
Regarding your questions about different depths within a single cabinet: Ikea Metod is designed so that cabinet units are available in two depths, but unfortunately, you cannot combine different depths within one unit. One option is to choose 60 cm (24 inches) deep units for the folders and books and place shallower drawer modules (e.g., 37 cm (15 inches)) in adjacent units or above/below.
Alternatively, you could use specially shallow drawer inserts in the 60 cm (24 inches) deep units that do not use the full depth, which helps keep things organized.
As for the countertop height: The standard Metod base cabinet height is 80 cm (31½ inches) including the countertop, which is slightly taller than 75 cm (29½ inches). You can make some adjustments here, for example by choosing a thinner countertop or using different leg options to modify the overall height.
I also recommend working with the Ikea planning tool during your design process, as it allows you to explore how different modules can be combined. Trying this out beforehand is very helpful.
If you like, I can create an example with specific measurements and combinations based on my own experience designing hobby rooms.
Good luck and don’t get discouraged – Metod can do more than it seems at first glance!
CHENFAR
13 Jan 2022 09:28
In addition to the previous points, I would like to highlight some practical details that are often overlooked but are especially important for the Ikea Metod system:
- Stability and fastening: Wall mounting is essential, especially for tall cabinets holding heavy items on shelves and in drawers. Use the supplied brackets and anchors, and before assembly, check if you have the appropriate screws for your wall type (drywall, concrete, etc.).
- Load capacity: Maximum load limits are stated in the assembly instructions. Typically, Metod cabinets can hold up to about 50 kg (110 lbs) per shelf, and drawers, depending on the runners, about 15-20 kg (33-44 lbs). If you plan to stack heavy binders, opt for shorter shelves with multiple levels.
- Interior fittings: For craft supplies, Ikea’s drawer inserts are arranged linearly and help keep things organized. Use smaller boxes (which are available in Ikea's range) or purchase separate organizers for small items. This improves visibility and speeds up work in your hobby room.
- Work surface: A working height of approximately 75 cm (30 inches) is ergonomically sound. Experts often recommend either customizing countertops or using adjustable feet under the Metod system to precisely set the height.
- Corner solutions: Using carousel units or pivoting shelves can help fully utilize corner storage, especially if the room is square or rectangular.
Conclusion: With good planning and consideration of the physical limits, the Metod system can be adapted very well. Get the latest IKEA product information before purchasing, as this includes all load capacities and exact dimensions.
If you can provide the room dimensions, I can suggest an optimized room layout for you.
