ᐅ How can I build an IKEA Besta as an L-shaped combination with more storage space and flexibility?
Created on: 12 May 2020 14:23
Goel32
Hello everyone, I am planning to assemble an IKEA Besta combination in an L-shape and want to maximize storage space and flexibility. Specifically, I would like to know how to best arrange the modules to mix both open compartments and closed cabinets effectively, while creating a thoughtful solution for changing needs, such as switching between TV equipment, office supplies, or collectibles. Which base modules should I choose, and what adjustments or additions (drawers, doors, legs, Varidesk components, etc.) would you recommend? Also, how can I ensure that the L-shaped combination remains stable and visually appealing? Tips on space planning and clever assembly tricks would be very helpful. Thanks in advance!
Teonon
14 May 2020 09:12
Your project sounds fantastic! Imagine having the flexibility to adjust your storage exactly how you want it or according to the season, thanks to modular units! My recommendation: build open compartments on one side for technical equipment and decorations, so you have easy access and a light appearance. Use the other side with doors and drawers to create a harmonious combination, giving you space for cables and more. And regarding your question about stability: be sure to secure everything to the wall, so it stands firmly! Don’t give up, it’s definitely worth it! 🙂
marcosku52
14 May 2020 10:43
Great question! I would also recommend planning modularly and using internal drawers. This way, you can store smaller items neatly while maintaining a clean look. For the L-shape, you can also use corner modules (if available) to make the most of the space. For flexibility, use small caster feet so you can move the units if needed – this gives you a lot of freedom in designing the room. Good luck! 😊
