ᐅ How can I build an L-shaped combination of Ikea Besta units to maximize storage space?
Created on: 20 Apr 2023 18:23
Kufe3
Kufe3
20 Apr 2023 18:23
Hello everyone, I am currently planning to furnish my living room with an L-shaped combination of Ikea Besta cabinets. My goal is to make the best use of the available space while creating maximum storage capacity. The layout should be as flexible and practical as possible, considering different cabinet heights and storage options (open shelves, doors, drawers). Does anyone have concrete experience or proven tips on how to best plan Besta units as an L-shaped combination to utilize every centimeter (inch) effectively? I look forward to practical suggestions regarding dimensions, modular combinations, and possibly useful accessories to maximize storage without compromising on aesthetics.
meoreo
20 Apr 2023 19:45
Hi, to maximize storage space, you should combine the Besta base frames at different heights – for example, 40cm (16 inches) and 64cm (25 inches). Use drawers at the bottom and open compartments at the top for flexible and easy access. An angle connector can help secure the modules in the corner.
nubar
21 Apr 2023 08:12
For planning an L-shaped Besta combination, I recommend the following:
- First, take precise measurements of the room and determine the cabinet depth (up to 40cm (16 inches) is common).
- Pay attention to stable corner solutions at the angle between the two cabinet runs to evenly distribute loads.
- Use adjustable shelves and drawer inserts inside for maximum storage flexibility.
- If the units are placed against walls, I recommend additional fastenings for increased stability.
- Soft-close doors can improve usability and add value.
This approach helps to make the best use of space and maintain a clean appearance.
Blavin
22 Apr 2023 11:39
Kufe3 schrieb:
My goal is to make the best use of the available space while maximizing storage capacity.
This is a fundamental question when configuring furniture. For an L-shaped Ikea Besta combination, I recommend the following structured approach:
- Plan based on a floor plan sketch with exact room measurements.
- Select cabinet units (Besta frames 60x40 cm or 60x64 cm height depending on storage needs).
- Use corner modules or connectors that provide a stable connection between the two cabinet rows without losing storage space.
- Design modularity with different fronts (doors, drawers, open compartments) to flexibly match storage requirements.
- Use adjustable shelves inside the cabinets, such as metal or wood, for various items.
- Additional storage aids like organizing boxes, drawer inserts, or hanging organizers can further optimize storage space.
- Consider stability by fastening cabinets to the wall and possibly using feet with adjustable height.
- Finally, choose a design so that the L-shape is not only practical but also visually appealing—for example, matching fronts that suit the room.
This structured approach ensures the combination fits well, stands securely, and uses storage space efficiently.
