ᐅ How can I build an Ikea BESTA wall unit with integrated LED lighting?
Created on: 1 Nov 2017 19:27
enistu
I am currently planning to remodel my Ikea Besta cabinet combination into a modern media wall with integrated LED lighting. My main goal is to create atmospheric indirect lighting installed inside the carcasses, behind the doors, or above the furniture, without the LED strips being directly visible. Clean wiring is important to me, preferably without visible cables, and ideally controlled via remote control or smartphone app.
My questions for the experts here are:
- Which LED light sources (manufacturers, types, color temperatures) work best with the BESTA modules for long-lasting use without producing too much heat?
- How have you managed the wiring when connecting and powering multiple modules?
- Are there special tips for mounting LED strips, especially regarding adhesion and preventing them from peeling off wood or glass over time?
- Do you use specific dimmers or controllers for the LEDs, and how have you discreetly integrated these into the media wall design?
I look forward to tips, instructions based on your experiences, or warnings about what to avoid. Thank you!
klo40
2 Nov 2017 09:46
Hello enistu,
as a supplement to the previous discussion, I would like to address safety and technical aspects:
- Use only low voltage (12V) to avoid fire hazards on wooden surfaces.
- When purchasing LED strips, pay attention to the IP rating if the lighting might be exposed to moisture.
- For control units, avoid cheap LED controllers; it’s better to choose well-known brands with good customer support.
- For cable management: it is often useful to drill small holes in the back panel of the Besta modules – this allows you to neatly hide cables, but be careful not to compromise structural stability.
- Adhesive bonds best to clean, dust-free surfaces – clean briefly with isopropanol beforehand.
These details are often underestimated but lead to durable results. From my experience, without careful installation, LEDs tend to detach or cables become loose within a year.
Good luck!
Franklin36
2 Nov 2017 11:18
One small tip, especially if you plan to install LEDs behind glass surfaces:
- Use diffuser channels or frosted covers to create a more even light distribution and avoid unattractive hotspots.
- For installation under shelves, flat aluminum profiles with LED strips work well, as they also act as heat sinks.
- Make sure the wiring is properly soldered or connected with suitable connectors—cheap connections can generate heat and become dangerous.
Installing a remote control or app-based control is easiest if you fully test and label all components before assembling the cabinet modules. This way, you’ll avoid tangled cables.
Franz
2 Nov 2017 12:37
luAlbert1 schrieb:
I basically think this whole LED thing is completely overrated.
I understand your point of view, but I wanted to say that warm indirect LED lighting, when done properly, can create a very cozy atmosphere. Especially if, like enistu, you make sure the light isn’t harsh but subtle.
Sepele schrieb:
Tips:
- Plan for plenty of extra cable length!
- Make sure the lighting is even, and don’t place strips too close to doors so the light isn’t too noticeable.
I followed these tips myself and the result is really harmonious. You shouldn’t get unsettled by too many opinions; what matters is that it suits your own style and that you enjoy it.
Good luck with that!
